POV-Ray : Newsgroups : povray.general : How do I create terrain without heightfields? Server Time
26 Apr 2026 10:31:09 EDT (-0400)
  How do I create terrain without heightfields? (Message 1 to 7 of 7)
Subject: How do I create terrain without heightfields?
Date: 6 Mar 2000 05:55:24
Message: <38c38e9c@news.povray.org>
Is there a tutorial somewhere on how to create realistic looking mountains
in POV without using image files as heightfields (for example using the
isosurfaces in MegaPOV)? Or could someone reply to this message and explain
the basics?
--ll
Subject: Re: How do I create terrain without heightfields?
Date: 6 Mar 2000 11:07:49
Message: <chrishuff_99-6CC216.11093006032000@news.povray.org>
In article <38c38e9c@news.povray.org>, "Lars Luthman" <no### [at] spamse>
> mountains in POV without using image files as heightfields (for
> example using the isosurfaces in MegaPOV)? Or could someone reply to
> this message and explain the basics?
Well, you can use a height field without an image, using a pattern
instead. To do that you use the "pattern" keyword. Here is the syntax
and a sample copied from the MegaPOV documentation:
pattern Width, Height { [ hf_gray_16] PIGMENT }
#declare QuickLandscape =
height_field {
    pattern 200, 200 {hf_gray_16 bozo
        color_map { [0 rgb 0] [1 rgb 1] }
There are many ways to do it with an isosurface, it depends on what kind
of terrain you are looking for. You could use the ridged multifractal
functions(which I have never used and don't know anything about), a
plane displaced with one or several noise3d() functions, or a plane
displaced with one or several pigments. Of the last two, mixing pigments
is more flexible but possibly slower.
An example:
#declare WrinklesFunc =
function {
    pigment {wrinkles
        color_map {[0 color Black][1 color White]}
isosurface {
    function {y - // the xy plane...
        WrinklesFunc(x, 0, z)*5 -
        WrinklesFunc(x*3, 0, z*3)*2
        // notice the y value is set to 0
        // If y is used in this part, overhangs
        // are possible.
    threshold 0
Chris Huff
e-mail: chr### [at] yahoocom
Date: 6 Mar 2000 11:43:57
Message: <38c3e04d@news.povray.org>
Thanks, I'll experiment a little with that.
--ll
Date: 6 Mar 2000 15:05:17
Message: <38c40f7d@news.povray.org>
Thankyou Chris, I hadn't thought of that - more time wasted experimenting!
Mick
       http://www.minda.swinternet.co.uk/index.htm
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-6CC216.11093006032000@news.povray.org...
> height_field {
> An example:
> function {
>     pigment {wrinkles
> isosurface {
>         // are possible.
>     threshold 0
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 6 Mar 2000 15:34:43
Message: <chrishuff_99-BF59FD.15362506032000@news.povray.org>
In article <38c40f7d@news.povray.org>, "Mick Hazelgrove"
It is only wasted if you didn't learn anything in the process...which I
doubt is true.
Chris Huff
Date: 6 Mar 2000 16:19:17
Message: <38c420d5@news.povray.org>
What I should have said was more time messin with Pov when I should be doing
some work!
Mick
news:chrishuff_99-BF59FD.15362506032000@news.povray.org...
experimenting!
> doubt is true.
> Chris Huff
Date: 6 Mar 2000 19:45:37
Message: <38C4503E.63DF5D3C@pacbell.net>
> some work!
I still can't see where that would be a problem :)
