POV-Ray : Newsgroups : povray.general : Here's an idea... Server Time
21 Jun 2026 22:12:08 EDT (-0400)
  Here's an idea... (Message 1 to 5 of 5)
Subject: Here's an idea...
Date: 9 Mar 2000 23:33:27
Message: <38C87A54.D0B38F44@faricy.net>
How 'bout, when POV parses a scene, it only loads macros and definitions
into memory if they're used. Because a lot of people make
general-purpose includes and don't use half of it for a particular
scene. This probably isn't worth it for smaller scenes, so maybe a
switch to turn it on, and normally it loads 'em all.
Then there's the whole wacky idea of a POV-script compiler, but I
realize that's probably much too much to ask :-)
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Subject: Re: Here's an idea...
Date: 10 Mar 2000 05:10:19
Message: <38c8ca0b@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote in message
news:38C87A54.D0B38F44@faricy.net...
Hmm, presumably, you'd have to parse each scene at least twice. The first
parse to find out what elements are actually used, the second to then check
the syntax of used macros etc.
Date: 10 Mar 2000 17:40:28
Message: <38C9791A.E9266B05@faricy.net>
Yes, but the first one would be just a real quick run-through...
Date: 10 Mar 2000 21:29:07
Message: <38C9B1EF.56F196F1@erols.com>
My latest IRTC entry uses about 6 Megs or so of memory.  My macro files
occupy less than 1% of this.  I think the POV team has bigger fish to fry.
John
Date: 11 Mar 2000 16:52:14
Message: <38CABF35.A79738AD@faricy.net>
That is why it must be turned on first. I assume your scene didn't use LEGO
elements... (hint hint)
