POV-Ray : Newsgroups : povray.general : how to speed it up Server Time
26 Apr 2026 17:49:19 EDT (-0400)
  how to speed it up (Message 1 to 2 of 2)
Subject: how to speed it up
Date: 30 Dec 1999 07:14:04
Message: <386b4c8c@news.povray.org>
Hi
I've convert some 3DS-Files to POV-Ray. Now the object looks like
#declare MyObj=union {
  union {  /* subobject 1 */
    triangle { <......
    triangle { <......
    triangle { <......
    triangle { <......
  union {  /* subobject 2 */
    triangle { <......
    triangle { <......
    triangle { <......
    triangle { <......
  texture { .... }
If I render the scene in POV-Ray, it Povray render as much as longer.
Example:
an empty room (4 Walls , one light source, 800 x 600) needs 2 minutes
with this 3DS-Object, which you is only 50 x 50 pixel large Povray needs 6
minutes, because povray need more time to render the wall, where you can't
see the objects. I hope you understood me.
Is there the posiblity to speed it up. I've tried bounded_by, but not with
better results. Could you give me an example or a tip?
thank you
  frank
Subject: Re: how to speed it up
Date: 30 Dec 1999 08:29:58
Message: <386b5e56@news.povray.org>
Use 'mesh' in place of 'union' for each 'triangle' section, but you still
need to 'union' them together as a whole.
"Frank Stolle" <sto### [at] gmxde> wrote in message
news:386b4c8c@news.povray.org...
> Hi
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>   texture { .... }
> Example:
> thank you
>   frank
