POV-Ray : Newsgroups : povray.general : Ellipse Server Time
27 May 2026 15:18:21 EDT (-0400)
  Ellipse (Message 1 to 3 of 3)
Subject: Ellipse
Date: 20 Dec 1999 14:23:22
Message: <385e822a@news.povray.org>
This may be a little OT, and I am embarrassed at having to ask this, but I
can't seem to find an equation that will allow me to draw an ellipse
(CENTERED ON THE ORIGIN) by stepping through an angle A. Given the x and y
axis radii, a and b, I want to start at zero angle and calculate a radius
measurement R (FROM THE ORIGIN) for that angle. My thinking is that I will
actually need to calculate x and y coordinates of the point on the ellipse
for the angle A, then take the square root of the sum of the squares of a
and b (did you follow that??). The angle A will step at some given interval,
say 5 degrees, all the way around the horn to 360. Eshabach's Handbook of
Engineering Fundamentals says the parametric form is:
y = b*sin(A)
x = a*cos(A)
My own scribblings got me to:
y = a*sin^2(A)
x = b*cos^2(A)
Anyone have any suggestions?
Jon
Subject: Re: Ellipse
Date: 20 Dec 1999 14:43:23
Message: <385E86DB.E541CDEE@ipfw.edu>
I think you're looking for a function of the angle A like this.
Radius = r = sqrt(x^2+y^2)
           = sqrt( (a*cos(A))^2 + (b*sin(A))^2 )
The sqrt(x^2+y^2), which you mentioned in your post, is the
"rectangular to polar conversion formula," AKA the Pythagorean
theorem.
The sqrt((a*cos(A))^2+(b*sin(A))^2) is just plugging the parametric
formulas (x = ..., and y = ...) into the first formula.
it could also be expanded a little into:
r = sqrt( a^2 * cos(A)^2 + b^2 * sin(A)^2 )
Adam C....
> y = b*sin(A)
> x = a*cos(A)
> y = a*sin^2(A)
> x = b*cos^2(A)
> Jon
Date: 4 Jan 2000 19:06:49
Message: <38728A45.C07295D@t-online.de>
> y = b*sin(A)
> x = a*cos(A)
This is an ellipse, but A is not the angle, but some unspecified
parameter (which nevertheless runs from 0 to 2pi).
The angle can be computed after this with the equation
phi = atan2(y,x)
if you need it (if your computing environment does not know
the function atan2, you will have to emulate it using atan(y/x)
and manual sign manipulation/constant addition).
> y = a*sin^2(A)
> x = b*cos^2(A)
This is a straight line (irrespective of what A stands for).
Ralf
