POV-Ray : Newsgroups : povray.general : Default folders for pov? Server Time
26 Apr 2026 19:47:32 EDT (-0400)
  Default folders for pov? (Message 1 to 10 of 16)
Subject: Default folders for pov?
Date: 11 Dec 1999 14:32:27
Message: <3852a6cb@news.povray.org>
Is there a way to set a default folder for my "*.pov" files other than in My
Documents?
Subject: Re: Default folders for pov?
Date: 11 Dec 1999 15:21:39
Message: <3852b253@news.povray.org>
Sure, check the Docs under File Output Options about 3/4 of the way down you
will find...
     Output_File_Name=c:\povray3\myimages\
    This will create c:\povray3\myimages\myscene.tga as the output file.
"AC" <amb### [at] teliacom> wrote in message news:3852a6cb@news.povray.org...
My
> Documents?
Date: 11 Dec 1999 17:21:14
Message: <3852ce5a@news.povray.org>
Think he meant for opening/saving of new pov script files not image output.
From what I can tell the answer is no.  I tried to see if I could tell
POV-Ray in the Windows registry to use a folder I wanted to use and found
nothing to cause it to see another place.  Actually I usually get the
C:\Windows folder, just sometimes the Documents, I want it to be in the
C:\Program Files\POV-Ray for Windows v3.1\scenes\ folder.
What's happening is the currently accessible folder Windows sees is getting
pointed to apparently, just took another look at where it wanted to go and
was C:\Temp this time.  I had recently used that folder for moving some
files around outside for Zip compressing and image opening.
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:3852b253@news.povray.org...
you
> will find...
in
> My
> > Documents?
Date: 11 Dec 1999 18:11:31
Message: <3852da23@news.povray.org>
"omniVERSE" <inv### [at] aolcom> wrote in message
news:3852ce5a@news.povray.org...
    Oh! That! I thought I was the only one with that problem and I only
seemed to have it since my last HD crash so I figured it was something I
could fix once I got around to it...
Date: 11 Dec 1999 22:21:32
Message: <385314bc@news.povray.org>
output.
getting
I don't use the Windows version myself, but it sounds like you're getting
Explorer's current directory as the open/save folder.  In this case, you
should be able to set a fixed folder in the properties of the shortcut to
POV-Ray (the Start In option)...maybe?
Date: 11 Dec 1999 23:11:54
Message: <k0865s0cmql2qrmpupb268l03dk9jmsp6r@4ax.com>
>Documents?
  Can you please set your system date correctly? Some newsreaders may
have trouble sorting messages properly when the date is wrong. Thanks.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 11 Dec 1999 23:33:22
Message: <38532592@news.povray.org>
    Yep, that's what I just did and it worked just fine. Right click on the
Icon or Start Menu Item and choose Properties then type in the path you want
in the "Start in" box.
Date: 12 Dec 1999 04:44:09
Message: <38536e69@news.povray.org>
Alan Kong <ako### [at] povrayNO-SPAMorg> wrote in message
news:k0865s0cmql2qrmpupb268l03dk9jmsp6r@4ax.com...
My
> >Documents?
Thanks for pointing at the time problem
By the way, I found a good solution to my problem....
I made a shortcut to the folder where I wanted to put my "*.pov" files and
put it in the My Documents folder, so now I only have to double click that
shortcut and I turn up at the right place......
But it would still be nice if they would put the featchure in Povray  4.0 .
For example under the options menu.
Date: 12 Dec 1999 05:34:10
Message: <0au65sc39pv1odf6snlcm0vacdi2q7ke31@4ax.com>
  I'll make a note of this request.
Date: 12 Dec 1999 07:48:40
Message: <385399a8@news.povray.org>
    It seems to me that POV used to remember where you were and open it up
there when you came back to it. Am I hallucinating or is that something that
was removed?
