POV-Ray : Newsgroups : povray.general : Illuminated Pie Chart Server Time
16 Jan 2026 15:56:07 EST (-0500)
  Illuminated Pie Chart (Message 1 to 4 of 4)
Subject: Illuminated Pie Chart
Date: 8 Dec 1999 18:22:43
Message: <384ee843@news.povray.org>
I would like to create a sector light, such as would be found on a small
boat.
It is rather like a pie chart with one part showing a red light, one part
green and one part remains black.
It is important that as the angle changes there is no black area between the
red and green nor any bleed from one color to the other.
2 spotlights with a very sharp fall-off looks about correct but how can I
fit two of them ( or more ) into a single cylinder?
Subject: Re: Illuminated Pie Chart
Date: 8 Dec 1999 18:41:46
Message: <chrishuff_99-E7191F.18420708121999@news.povray.org>
In article <384ee843@news.povray.org>, "David Vincent-Jones"
> boat.
> the
If I understand what you want, try using a sphere with a radial pattern,
and a color map divided into a red section, a green section, and a black
section. Give the red and green a filter of 1, place a spotlight inside
the sphere, oriented correctly, and use the reorient macro or just
transforms to move it into position.
Oh, it helps to know that you can add light_sources to a union, that
makes keeping everything together much easier.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 9 Dec 1999 03:29:29
Message: <384f6869@news.povray.org>
> boat.
the
How about recreating the light just as it would be in real life, ie. put a
white light source behind a coloured filter with the pattern you desire, eg:
camera {location <1, 1, -3> look_at <0, 0, 10>}
light_source {<-100, 200, -400> rgb .5}  // Filler light
plane {z, 10 pigment {checker rgb .5, rgb 1}}
union {
   light_source {0, rgb 1
      spotlight point_at z radius 30 falloff 45}
   disc {z*.1, z, 1 hollow
      pigment {radial color_map {
         [.3 rgb 0] [.3 rgbf <1, 0, 0, 1>]
         [.7 rgbf <1, 0, 0, 1>]  [.7 rgbf <0, 1, 0, 1>]}
         rotate x*90}}
   scale .001} // Scale very small so filtering disc isn't visible
You can use all sorts of filtered pigments (including image maps and
animated pigments) to create projections of just about anything you want...
Date: 9 Dec 1999 09:29:19
Message: <384FBCCD.2BE5221B@giwersworld.org>
> boat.
	Another real life approach is to put a physical partition
between two lights.
