POV-Ray : Newsgroups : povray.general : Make the most of your Ram Server Time
27 May 2026 16:32:45 EDT (-0400)
  Make the most of your Ram (Message 1 to 4 of 4)
Subject: Make the most of your Ram
Date: 26 Nov 1999 19:03:47
Message: <383f1fe3@news.povray.org>
Just came across this program at http://www.outertech.com
Not sure if it will help much but it's worth a try
Cacheman
Cacheman is a utility which tweaks the disk
cache settings and prevents frequent swapping
of the data to disk resulting in an improved
performance and stability.
It works on the VCache:
VCACHE is drive cache Windows allocates that can often
gobble up 25-40% of your installed memory.  By default
Windows places NO LIMIT on how large it can be.
Wonderful....
Hope it's useful to someone
Kev
Subject: Re: Make the most of your Ram
Date: 26 Nov 1999 19:59:35
Message: <383F2B32.3E864212@global2000.net>
I already have it!  What are good settings for someone who uses POV-Ray?
Brendan Ryan
> Cacheman
> Wonderful....
> Kev
Date: 26 Nov 1999 22:18:17
Message: <383f4d79@news.povray.org>
I'll be fine, my computer doesn't ever disk swap unless I'm doing some
massive render in MAX or adding huge layers in Photoshop :)
Lance.
The Zone - http://come.to/the.zone
Date: 27 Nov 1999 01:07:54
Message: <383f753a@news.povray.org>
Brendan Ryan wrote in message <383F2B32.3E864212@global2000.net>...
My computer has 128 MB of RAM, and I've got the cache set so that it takes
between 4MB and 10MB of memory.  The main thing I use CacheMan for is so
that during renderings that take up a lot of memory I can check and see if
POV-Ray is using up all the physical memory on my computer or not so that I
can abort the render if it is.
Mark
