POV-Ray : Newsgroups : povray.general : phong bug Server Time
27 May 2026 20:52:57 EDT (-0400)
  phong bug (Message 1 to 2 of 2)
Subject: phong bug
Date: 21 Oct 1999 17:21:48
Message: <380f83ec@news.povray.org>
I believe the phong highlights in POV-Ray has a bug.
When you have a reflective object with a heavy normal then some of the
reflected rays would actually go *inside* the object, but luckily POV-Ray
prevents this some way.
Unfortunately POV-Ray doesn't prevent it with phong highlights, i.e. the
surface *can* "reflect" a light_source which is behind or inside the object.
I think POV-Ray should prevent it like it does with reflection.
Greetings,
Rune S. Johansen
Updated October 17: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Subject: Re: phong bug
Date: 21 Oct 1999 19:18:22
Message: <380f9f3e@news.povray.org>
Interestingly enough, in 3.1a and prior versions, you could reflect through
objects by using normals.
-Nathan
Rune S. Johansen <run### [at] inamecom> wrote...
object.
> Greetings,
> Rune S. Johansen
