POV-Ray : Newsgroups : povray.general : A color component extraction bug? Server Time
11 Aug 2024 01:23:01 EDT (-0400)
  A color component extraction bug? (Message 1 to 5 of 5)
Subject: A color component extraction bug?
Date: 20 Oct 1999 03:34:30
Message: <380d7086@news.povray.org>
Hi everybody!
It has been quite a long time since I last posted here - or used POV
for that matter. Probably a year. For my defence I must say I had no
occasion to do so - no time, no computer and/or no phone line (hence no
Internet access). I now have my computer back, some more time and a
good connection at work (ISDN).
I have been browsing news.povray silently for two weeks. It is really
good to read all of you again.
SO
As I am back to using POV, I am back to having problems with it. Can
anybody tell me what's wrong here?
I got a problem with colour component extraction. It seems that when
you use colour component extraction and use the result immediately,
what you got is a float. But if there is an intermediate step
(#declare, #local or pass as a macro argument), it reverts to a colour.
In other word:
floatFunction(aColor.red) is OK, but
#declare myFloat=aColor.red is not a float but a colour
I suspect this is a bug. But of course I could be wrong (would not be
the first time). Could you please check? I browsed p.bugreports but
could find nothing related.
Here is an illustration of the problem, along with some tests to narrow
it:
(All the lines that cause an error before 'no object in scene' are
commented.) (All 'should work' or 'should fail' are based on what I
expect POV to do.)
#declare LightBrown=color rgb <1,.5,.3>; // declare a color
#declare BlueComponent=LightBrown.blue;  // extract blue component
                                         // this should be a float
/* Quote from doc :
You may use the dot operator to extract a single component from a
color. Suppose the identifier Shade was previously defined as a color.
Then Shade.red is the float value of the red component of Shade.
Similarly Shade.green, Shade.blue, Shade.filter and Shade.transmit
extract the float value of the other color components.
// The simplest illustration
#declare Test1=abs(LightBrown.blue);    // this works
// #declare Test2=abs(BlueComponent);      // this fails
// With macros:
// Direct return without assignment
#macro Test3Macro(cColor)
  cColor.blue
#declare Test3=abs(Test3Macro(LightBrown)); // this works
// Return with #local
#macro Test4Macro(cColor)
  #local Test4Return=cColor.blue;
  Test4Return
#declare Test4=abs(Test4Macro(LightBrown)); // this fails
// Color component as an argument
#macro Test5Macro(fFloat)
  abs(fFloat);
#declare Test5=Test5Macro(LightBrown.blue); // this fails
// Q: What type is BlueComponent?
// A: color!
// #declare BlueComponent=LightBrown;      // this works and should not
// #declare BlueComponent=pi;              // this fails but should work
#declare BlueBlueComponent=BlueComponent.blue;         // this works OK
// #declare BlueBlueComponent=pi;          // this fails but should work
// Q: If BlueComponent is a color, is it rgbft<0,0,blue,0,0>?
// A: It seems BlueComponent = color blue, giving
//    rgbft <blue,blue,blue,blue,blue> with operator promotion.
//   read the #debug stream
#debug "\n\n BlueComponent=rgbft < "
#debug str(BlueComponent.red,2,2)
#debug ", "
#debug str(BlueComponent.green,2,2)
#debug ", "
#debug str(BlueComponent.blue,2,2)
#debug ", "
#debug str(BlueComponent.filter,2,2)
#debug ", "
#debug str(BlueComponent.transmit,2,2)
#debug " >\n\n"
// Q: What about the other components?
// A: Same problem.
#declare RedComponent=LightBrown.red;
// #declare Test9=abs(RedComponent);       // this fails but should work
#declare GreenComponent=LightBrown.green;
// #declare Test10=abs(GreenComponent);    // this fails but should work
#declare FilterComponent=LightBrown.filter;
// #declare Test11=abs(FilterComponent);   // this fails but should work
#declare TransmitComponent=LightBrown.transmit;
// #declare Test12=abs(TransmitComponent); // this fails but should work
// Testing myself for sanity
// #declare test13=pi.blue;         // this fails OK - as it should
// #declare test14=abs(LightBrown); // this fails OK
#declare test15=<1,2,3>.x;
#declare test15=pi;                // this works OK
#declare test16=<1,2,3>.red;
#declare test16=pi;                // this works OK
#declare test17=rgb <1,2,3>;
#declare test17=test17.blue;       // this works and should not
// #declare test17=pi;              // this fails OK
#declare test18=color rgb <1,2,3>;
#declare test18=test18.blue;       // this works and should not
#declare test18=test18.x;          // this works and should not
// #declare test18=pi;              // this fails OK
// #declare test19=color <1>;         // this fails OK
#declare test20=color 1;           // this works
#declare test21=abs(LightBrown.blue);// this works OK
#declare test21=pi;                  // this works OK
Subject: Re: A color component extraction bug?
Date: 20 Oct 1999 13:12:09
Message: <380df7e9@news.povray.org>
Read the section titled Common Color Pitfalls, explains there that this is a
known problem not a bug. Suggests workarounds, one way being to enclose the
dot product in parentheses, like so:  #declare RedFloat=(Shade.red)
Philippe Debar <phi### [at] hotmailcom> wrote in message
news:380d7086@news.povray.org...
> Hi everybody!
> SO
> In other word:
> it:
> expect POV to do.)
> /* Quote from doc :
> // With macros:
>   cColor.blue
> #end
>   Test4Return
> #end
>   abs(fFloat);
> #end
> // A: color!
> #debug ", "
> #debug ", "
> #debug ", "
> #debug ", "
> #debug " >\n\n"
> // A: Same problem.
Date: 20 Oct 1999 13:13:36
Message: <380DF833.21FC33F8@enst.fr>
> In other word:
	AFAIK this is due to the fact that pov uses the first thing it
encouters after the "=" sign to determine the type of the variable.
#declare myFloat=aColor.red is a color because aColor is used to
determine the type, but:
#declare myFloat=0+aColor.red is a float as expected...
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 22 Oct 1999 02:59:50
Message: <38100b66@news.povray.org>
omniVERSE <inv### [at] aolcom> wrote in message
news:380df7e9@news.povray.org...
a
the
> Bob
Thank you! I think I didn't check that section of the doc since v2.x ... I
thought it was stuff like 'if you define color rgbf 0 you get a black
object, not an invisible one'.
Message: <38100b66$1@news.povray.org>
Jerome M. BERGER <jbe### [at] enstfr> wrote in message
news:380DF833.21FC33F8@enst.fr...
Many thanks for the explanation.
