POV-Ray : Newsgroups : povray.general : Star Macro Server Time
16 Jan 2026 22:46:31 EST (-0500)
  Star Macro (Message 1 to 10 of 15)
Subject: Star Macro
Date: 10 Oct 1999 21:22:40
Message: <38013AE9.7AC40514@global2000.net>
Is it a good idea to make stars by using CSG or should they be solid
blocks?
Brendan Ryan
Subject: Re: Star Macro
Date: 10 Oct 1999 21:29:31
Message: <38013DF4.E8215D05@compuserve.com>
It kind of depends on what you are trying to do...
You could use a prism, CSG of a prism, a polygon, a mesh, etc. What are
you trying to accomplish?
Date: 10 Oct 1999 21:41:05
Message: <38013F38.3D16055F@global2000.net>
I'll try to make solid star prisms if I find out how to move a point
towards the origin.
Brendan Ryan
> blocks?
> Brendan Ryan
Date: 10 Oct 1999 21:47:27
Message: <38014224.D54E532A@tapestry.tucson.az.us>
> towards the origin.
> Brendan Ryan
Multiply the coordinates of your point by the fraction of how much closer
you want the point to be to the origin.  For example, if you have a point
<x,y,z> and you want it to be only half as far away from the origin, it's
new coordinate will be .5*<x,y,z>
Date: 11 Oct 1999 12:10:58
Message: <38020B13.83CA3CA1@global2000.net>
I tried to divide every other vector by ptmove but it didn't work. This code
rotates and moves the odd numbered points and just rotates the even numbered
points. The code is in a while loop. Rotation_no and point_no both get added
to one at the end.
Brendan Ryan
#local determine = (point_no/2)-int(point_no/2);
#switch (determine)
#case (0.5)  //odd numbered point
#local vec =vrotate(<0,1,0>,<0,0,(angle_of_rotation*rotation_no)>/ptmove);
#break
#case (0) //even numbered point
#local vec=vrotate(<0,1,0>,<0,0,angle_of_rotation*rotation_no>);
#break
Kevin Wampler wrote:
> > towards the origin.
> > Brendan Ryan
Date: 11 Oct 1999 13:30:06
Message: <38021F0C.13CEB0E5@tapestry.tucson.az.us>
> to one at the end.
> Brendan Ryan
> #switch (determine)
> #break
> #break
> #end
The problem here is that you divided by ptmove within the vrotate() statement.
Change the fourth line to this:
#local vec  =  vrotate(<0,1,0>,<0,0,angle_of_rotation*rotation_no>)/ptmove;
and it should work.
Date: 11 Oct 1999 13:43:01
Message: <38022197.FA123A16@enst.fr>
> and it should work.
	Or faster:
vrotate(<0, 1/ptmove, 0>, <0,0,angle_of_rotation*rotation_no>);
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 11 Oct 1999 13:57:17
Message: <380223FE.D9AE3942@global2000.net>
Thanks! A five pointed star was rendered! I'll refine the code because the star is
really a decagon. The number of sides a star has is twice the number of points it
has. I'll divide the vector by the distance between the vertex of the decagon and
the midpoint of a pentagon inside the decagon to turn the decagon into a pentagon
with controllable midpoints.
Brendan Ryan
P.S. I call the distance "r" and it is equal to
(tan(180-(90+(180*((2*points)-2))/(2*points)/2)))*(cos(((180*(points-2))/points)/2))
where points is the number of points (the kind that look like arms, not the
vectors) that the star has.
I'll also be posting pictures of stars in the povray.binaries.images group.
> > to one at the end.
> > Brendan Ryan
> > #switch (determine)
> > #break
> > #break
> > #end
> and it should work.
Date: 11 Oct 1999 15:28:29
Message: <3802395C.D6E626C4@global2000.net>
I have two pov files with the same contents and they both include the
include file that has the star macro. I can render a image with one of
the files but with the other file, I can't render a image. Both files
have the line
starbl (0,0,0,1,1,1,0,1,5,4)
"starbl" is the macro's name but it says that 'starbl' is an undeclared
identifier.
Thanks.
Brendan Ryan
> blocks?
> Brendan Ryan
Date: 11 Oct 1999 16:39:36
Message: <38024b08@news.povray.org>
Is it saved in a different directory? and is your macro file in the include
file and is the include file in your include path?
Andrea Ryan <ary### [at] global2000net> wrote in message
news:3802395C.D6E626C4@global2000.net...
> have the line
> identifier.
> Thanks.
> Brendan Ryan
> > blocks?
> > Brendan Ryan
