POV-Ray : Newsgroups : povray.general : Smooth random Server Time
27 May 2026 20:51:30 EDT (-0400)
  Smooth random (Message 1 to 10 of 11)
Subject: Smooth random
Date: 9 Oct 1999 23:31:16
Message: <380008D1.9E67470B@isd.net>
How can I get a smooth random number, ie, it varies from the last random
number by no more than a certain amount? (I'm making a tree macro and
want a way to twist the limbs.)
Subject: Re: Smooth random
Date: 9 Oct 1999 23:39:45
Message: <38000A77.65B88081@pacbell.net>
I'll send you a possible solution by email. I would post the source but
it's a bit longish for this group.
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 10 Oct 1999 10:51:33
Message: <facAOGA2qGrV7lLFLS+8zDOcVwj8@4ax.com>
On Sat, 09 Oct 1999 22:32:33 -0500, Larry Fontaine <lfo### [at] isdnet>
There's a smooth random generator in the Throroughly Useful Macros by
John VanSickle. Search Ken's links :)
Peter Popov
ICQ: 15002700
Date: 10 Oct 1999 11:07:44
Message: <3800AB52.9D98B08C@pacbell.net>
> Peter Popov
> ICQ: 15002700
I already sent it to him :)
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 10 Oct 1999 14:50:07
Message: <3800DFA8.54B90134@peak.edu.ee>
I'm not sure what you're after. The smooth rand macro is one solution.
I can also send you a Perlin noise macro I created. It takes a float as the
parameter and returns values within a certain limit. Close parameters give
statistically close values. The result is similar to turbulence - you have
control over octaves and omega - but the noise is 1D, i.e. it returns a float.
Let me know if you're interested, because I'd have to clean up the source before
posting it.
Margus
Date: 11 Oct 1999 06:05:15
Message: <3801b65b@news.povray.org>
Larry Fontaine <lfo### [at] isdnet> wrote:
: How can I get a smooth random number, ie, it varies from the last random
: number by no more than a certain amount?
  If you mean a linear distribution, that's pretty simple:
#declare Seed = seed(0);
#declare Number = rand(Seed);
#macro NextNumber(maxvariation)
  #declare Number = Number-maxVariation+maxvariation*rand(Seed)*2;
  Number
Date: 11 Oct 1999 09:58:53
Message: <3801ECE8.15BDCAA9@peak.edu.ee>
AFAIK, this is normal distribution.
I made two little macros that do normal distribution for floats and 3D vectors
(it's trivial to extend it to nD vectors). They take the mean, the maximum
deviation and a predeclared seed as parameters.
The macros are available from the Macroscope (rand_ext and v_rand_ext)
Margus
Date: 11 Oct 1999 11:15:29
Message: <3801ff11@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: AFAIK, this is normal distribution.
  No, normal distribution is distributed in the form e^(-x^2). You can get
an approximation by calculating the average of at least three random numbers
(the more the numbers, the better the approximation, but three is usually
close enough).
Date: 11 Oct 1999 12:54:01
Message: <380217A6.4861EB83@merlin.net.au>
> close enough).
The more random numbers summed, the smaller the standard deviation.
PoD.
Date: 11 Oct 1999 20:56:48
Message: <38028723.6BE157C2@peak.edu.ee>
> PoD.
But that's just a relative measure, anyway. You can increase dispersion by
scaling with the mean as the origin.
Margus
