POV-Ray : Newsgroups : povray.general : No pointlight atmospheric media interaction? Server Time
27 May 2026 20:52:49 EDT (-0400)
  No pointlight atmospheric media interaction? (Message 1 to 8 of 8)
Subject: No pointlight atmospheric media interaction?
Date: 6 Oct 1999 20:17:58
Message: <37fbe6b6@news.povray.org>
I cannot get a pointlight to interact with atmospheric media. What's up?
When I put a spotlight here, it looks cool.  The pointlight, however,
doesn't do a thing....
light_source{<0.005,0.00081,0.00081>  color White*14
media_interaction on}
  light_source {  <0,0,0>
    color White*14
    spotlight
    radius 90
    falloff 89//28
    tightness 1
    point_at x
media {                         //media scattering
  intervals 10
  scattering { 2, red 0.05 blue 0.001 green 0.02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
Subject: Re: No pointlight atmospheric media interaction?
Date: 6 Oct 1999 20:42:35
Message: <37FBEC6B.357CE6B5@enst.fr>
>     color White*14
>     spotlight
>     radius 90
>     falloff 89//28
>     tightness 1
>     point_at x
>   intervals 10
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
	Is there anything else in the scene besides the media and the light? If
not, that's because when you use a spotlight, the samples get
concentrated in the lighted cone so the effect is visible, whereas for a
pointlight they are distributed along the whole ray and if there's
nothing to stop it, the ray goes to infinity... (in fact that's why
rather than using atmospheric media, I usually use object media in a
very large container: it's easier to tune)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 7 Oct 1999 06:42:55
Message: <37FC7899.AB1E477@my-dejanews.com>
Okay, thanks for the suggestion.  However, I already tried the "container media"
and the effect was not nearly as cool as that for the spotlight and atmospheric
media.
>                 Jerome
> * Then do it.                 *
Subject: bug: No pointlight atmospheric media interaction!
Date: 7 Oct 1999 09:17:35
Message: <37FC9CD6.9B9261F4@my-dejanews.com>
On second thought, I will repeat my complaint that point lights DO NOT WORK with
atmospheric media. This is either a bug or a design flaw.
I wanted the effect of a light bulb inside a wiffle ball in the fog.  I set up a
porous object (based on 3d noise), but a point light inside, and had NO effect.  I
removed my porous object.  There was still no effect.  Thus, I conclude that point
lights do not interact with atmospheric media.
> media.
> >                 Jerome
> > * Then do it.                 *
Date: 7 Oct 1999 09:36:21
Message: <37FCA1C6.54C9971C@pacbell.net>
>     color White*14
>     spotlight
>     radius 90
>     falloff 89//28
>     tightness 1
>     point_at x
>   intervals 10
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
This works for me using your media and my camera. Turn the media_interaction
off and the media dissappears. Turn the media_interaction on and the media
appears. I don't know what your problem is but it's not Pov's fault.
    location <0, 0, -1>
    look_at <0, 0, 0>
    angle 75
   intervals 10
   samples 1, 10
   confidence 0.9999
   variance 1/1000
   ratio 0.9
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: No pointlight atmospheric media interaction!
Date: 7 Oct 1999 15:50:32
Message: <37fcf988@news.povray.org>
They worked for me. They've always worked. I suggest you add fade_power and
fade_distance. And media_interaction on.
Date: 8 Oct 1999 01:22:08
Message: <37fd7f80@news.povray.org>
Greg M. Johnson wrote in message <37FC9CD6.9B9261F4@my-dejanews.com>...
with
Having gone through the source code for media, I have determined that media
DOES work with point lights.
Mark
Subject: Bug in superpatch 3.1
Date: 9 Oct 1999 10:26:16
Message: <37ff5088@news.povray.org>
Ken's code works in pov 3.1g, but not in the superpatch for 3.1e.
And as I complained in p.b.i.,   a spotlight looks so much cooler. WHY?
>   camera {
>     location <0, 0, -1>
>     look_at <0, 0, 0>
>     angle 75
>    intervals 10
>    samples 1, 10
>    confidence 0.9999
>    variance 1/1000
>    ratio 0.9
> Ken Tyler
