POV-Ray : Newsgroups : povray.general : Blob Math Server Time
23 Jun 2026 06:09:47 EDT (-0400)
  Blob Math (Message 1 to 10 of 15)
Subject: Blob Math
Date: 26 Sep 1999 17:04:17
Message: <37EE8A2E.CAB947B3@mcmaster.ca>
Does anyone (Ken?) have any good references to the mathematics of blobs?
Ideally 2D blobs explained at a fairly simple level. I have some
theories about how to program a lava lamp and blobs seem to be a good
way of accomplishing what I want.
Thanks,
Chris Maryan
mailto: mar### [at] mcmasterca
Will work for cash.
Email me if you are interested in donating
to the Chris Maryan needs money fund.
We will also accept donations to the Chris
needs a Pentium III or SGI workstation
fund and the Chris needs a car fund.
Subject: Re: Blob Math
Date: 26 Sep 1999 19:22:27
Message: <37EEAA92.6CB17750@peak.edu.ee>
The manual gives a fairly complete overview of the blob object, complete with
the falloff formula. Other than that, what mathemathics are you referring to?
Margus
> Thanks,
> Chris Maryan
> Will work for cash.
Date: 26 Sep 1999 19:34:18
Message: <37eead7a@news.povray.org>
In article <37EEAA92.6CB17750@peak.edu.ee> , Margus Ramst
Perhaps he is looking for how exactly blobs work. It is a bit technical but
maybe this (for the source code) helps:
* FUNCTION
*   All_Blob_Intersections
* INPUT
*   Object      - Object
*   Ray         - Ray
* OUTPUT
*   Depth_Stack - Intersection stack
* RETURNS
*   int - true, if a intersection was found
* AUTHOR
*   Alexander Enzmann
* DESCRIPTION
*   Generate intervals of influence for each component. After these
*   are made, determine their aggregate effect on the ray. As the
*   individual intervals are checked, a quartic is generated
*   that represents the density at a particular point on the ray.
*   Explanation for spherical components:
*   After making the substitutions in MakeBlob, there is a formula
*   for each component that has the form:
*      c0 * r^4 + c1 * r^2 + c2.
*   In order to determine the influence on the ray of all of the
*   individual components, we start by determining the distance
*   from any point on the ray to the specified point.  This can
*   be found using the pythagorean theorem, using C as the center
*   of this component, P as the start of the ray, and D as the
*   direction of travel of the ray:
*      r^2 = (t * D + P - C) . (t * D + P - C)
*   we insert this equation for each appearance of r^2 in the
*   components' formula, giving:
*      r^2 = D.D t^2 + 2 t D . (P - C) + (P - C) . (P - C)
*   Since the direction vector has been normalized, D.D = 1.
*   Using the substitutions:
*      t0 = (P - C) . (P - C),
*      t1 = D . (P - C)
*   We can write the formula as:
*      r^2 = t0 + 2 t t1 + t^2
*   Taking r^2 and substituting into the formula for this component
*   of the Blob we get the formula:
*      density = c0 * (r^2)^2 + c1 * r^2 + c2,
*   or:
*      density = c0 * (t0 + 2 t t1 + t^2)^2 +
*                c1 * (t0 + 2 t t1 + t^2) +
*                c2
*   Expanding terms and collecting with respect to "t" gives:
*      t^4 * c0 +
*      t^3 * 4 c0 t1 +
*      t^2 * (c1 + 2 * c0 t0 + 4 c0 t1^2)
*      t   * 2 (c1 t1 + 2 c0 t0 t1) +
*            c2 + c1*t0 + c0*t0^2
*   This formula can now be solved for "t" by any of the quartic
*   root solvers that are available.
* CHANGES
*   Jul 1994 : Added code for cylindrical and ellipsoidical blobs. [DB]
*   Oct 1994 : Added code to convert polynomial into a bezier curve for
*              a quick test if an intersection exists in an interval. [DB]
*   Sep 1995 : Added code to avoid numerical problems with distant blobs.
[DB]
e-mail: tho### [at] trfde
Date: 26 Sep 1999 21:06:08
Message: <37EEC125.44748786@isd.net>
AARGH!!!!!!!
I wanted to do a lava-lamp :-(
And here I spent all this time on a rounded-cone macro. Long equations it
has.
> Thanks,
> Chris Maryan
> Will work for cash.
Date: 27 Sep 1999 11:10:13
Message: <37EF88B4.AC48D8C3@mcmaster.ca>
Having done some more research on blobs, I realize now that they may not
be the best thing. Specifically, I need to define a point (which is free
to move around according to lava-lamp physics). This point has an area
around it (this would have been the blob) that  is there only for
graphical purposes. The area would be spherical when the center point is
away from any other center point/area groups and would blend together
with other groups when they are close (Think blobs, defined by a center
point and having a specific radius when not influenced by other blobs).
I think the following may be a more useful solution (and it might be
more within my mathematical ability) (see diagram below):
A spline of some sort would be pulled around the 'x's (thus spherical
when uninfluenced). When the center 'X' gets close enough to another
group, the spline would be stretched around the 'x's of both groups.
Either way, I have some ideas, but would love to know if anyone else has
any thoughts, but for now, I'm off to a lecture, thanks for the help.
      x     x
         X
      x     x
> Margus
> > Thanks,
> > Chris Maryan
> > Will work for cash.
Chris Maryan
Will work for cash.
Date: 27 Sep 1999 11:19:56
Message: <37EF8B64.F91B180A@xs4all.nl>
>       x     x
>          X
>       x     x
I've seen results some time ago from a demo-coding competition with a lavalamp
as subject and as far as I can remember the most convincing ones used an
algorithm similar to blob (or at least so I interpreted it - hmm...).
I had the URL at hand but can't seem to find it right now. If you really like I
think I can dig it up. Most of the entries had the sourcecode included.
Good luck,
Remco
Date: 27 Sep 1999 11:35:52
Message: <37ef8ed8@news.povray.org>
This isn't true of the lava lamp in my son's room.  The blobs in his
lamp don't tend to merge due to surface tension and/or temperature effects,
so most of them end up being either spherical or ellipsoidal after they
separate from the mass of wax at the bottom of the lamp.  They tend to
change eccentricity as they rise, due to oscillations induced by the "neck"
breaking and a large quantity of wax being pulled toward the center of
the blob by surface tension.  There is also an area at the top of the lamp
populated by a bunch of spheres of various sizes, packed together (and thus
no longer spherical, but you might get away with representing them as spheres
for POV purposes.)  Every now and then, one of those spheres cools off enough
to sink back to the bottom but it doesn't attempt to merge with blobs on their
way up; it seems to bounce or roll off of them.  How long it takes a sphere to
cool and fall is probably a complex function of its radius (the ratio of volume
to surface area is proportional to radius) and its position within the cluster
(the temperature gradient is probably higher near the outside of the lamp, so
heat transfer takes place more quickly.)
Date: 27 Sep 1999 18:03:06
Message: <37EFE977.7E7F6AFC@mcmaster.ca>
I studied real lava lamps a bit to get the basis for this project and
have come to the conclusion that wax that blobs together is considerably
more interesting. I think my interpretation of the physics of the motion
is fairly complete, at least to the point that it could fake what really
happens fairly well. The only thing missing is some algorithms for the
graphics/blobing.
Chris Maryan
Will work for cash.
Date: 27 Sep 1999 18:20:09
Message: <37EFED76.EB48DE14@mcmaster.ca>
I tried looking for this myself, but I couldn't find it. If you have
some idea of where else to look, I would appreciate it. Thanks
> Good luck,
> Remco
Chris Maryan
Will work for cash.
Date: 27 Sep 1999 19:03:36
Message: <37EFF810.38C5C0D1@xs4all.nl>
> > Good luck,
> > Remco
> Chris Maryan
Well, it appears the link I had is dead. <8{
I still have some of the demos from the site but not all of them have sources
(the best not - of course...). If you like I could mail the package (<1Mb).
I would give you some URLs but the ones I tried have appear to be all
outdated...
Sorry.
Remco
