POV-Ray : Newsgroups : povray.general : real reflection Server Time
22 Jul 2026 11:11:45 EDT (-0400)
  real reflection (Message 1 to 3 of 3)
Subject: real reflection
Date: 30 Aug 1999 06:56:31
Message: <37CA62F9.55E2A91F@robotica.dnttm.ro>
Normally, if an object is illuminated, it becomes a small source of
light for other objects. (For example you can see the light of the sun
reflected by water on the trees... etc)
How can I simulate this in povray?
Subject: Re: real reflection
Date: 30 Aug 1999 07:25:47
Message: <37CA69FE.628F944C@pacbell.net>
There are two ways you may approach this. The radiosity feature in Pov
is designed to simulate inter diffuse reactions between objects. It is
inherently better suited for some situations more so that others. From
your discription it sound more like you are seeking the mirrored disco
ball effect where you can bounce light off a mirrored surface and see
it's reflection on other objects - something that the official version
of Poray cannot do. However Nathan Kopps UV Patch of Povray has a feature
called photon mapping that adds this functionality and is quite easy
to use. To see some examples and download the UV Patch follow the link
provided.
http://nathan.kopp.com/patched.htm
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 30 Aug 1999 11:34:44
Message: <37caa494@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: There are two ways you may approach this. The radiosity feature in Pov
: is designed to simulate inter diffuse reactions between objects.
  For some examples about this, see:
http://iki.fi/warp/pics/Radiosity_test2/
