POV-Ray : Newsgroups : povray.general : Working with Text Server Time
27 Apr 2026 11:48:48 EDT (-0400)
  Working with Text (Message 1 to 10 of 21)
Subject: Working with Text
Date: 27 Jul 1999 19:54:43
Message: <379e46c3@news.povray.org>
Can't seem to find much on working with text as graphic objects.  The POV
package has an example which, blissfully, uses True Type fonts.
In addition to color and texture, I would like to bevel, round the face,
illuminate from inside, wrap the line of text around a sphere or cylinder
(inside or out) and the like.
Any thoughts?
Thanks,
Matt
Subject: Re: Working with Text
Date: 27 Jul 1999 20:42:03
Message: <379e51db@news.povray.org>
There are ways to do these things. Do you mean as actual features
internal to POV-Ray or as scripted in a file? Take a look at this URL
here if you haven't already.
 http://www.xs4all.nl/~remcodek/softtext.html
> Any thoughts?
> Thanks,
> Matt
 mailto://inversez@aol.com?Subject=PoV-News
Subject: Re: Working with Text Objects
Date: 28 Jul 1999 03:48:27
Message: <379eb5cb@news.povray.org>
Hi Bob:
While I have greater aspirations for POV-Ray than eye-candy typography
(Hey... I LIKE candy!), my most immediate need is to produce gooey, shiney,
sparkling, fancy and eye-catching titles and logos for web graphics.
Crude starting example at:  http://member.aol.com/ideatoys/logos.htm
Sure, there are plenty of $10 programs out the which bevel, level and
dishevel fonts, then coat, color and wet them down.    I want to do ALL
those naughty things to letters, and then some-- I just want to do it under
programmatic control.
If I can do the grunt work in Moray or somesuch, fine--  so long as I can
change the text string, color, size, etc., using a parameter file.
I'll study the link you kindly provided.  My choice at this point, however,
because of the vast number available, would be to use TrueType fonts as
starting points.
Any thoughts?
Thanks,
Matt
Bob Hughes wrote in message <379e51db@news.povray.org>...
>> Any thoughts?
>> Thanks,
>> Matt
> omniVERSE: beyond the universe
>  http://members.aol.com/inversez/homepage.htm
Date: 28 Jul 1999 07:53:44
Message: <379eef48@news.povray.org>
If the softtext utility outputs triangle meshes, you could use the PCM
macro to do even more transformations to the fonts (like adding spikes or
growing hair to them or morphing them) which are not possible with softtext.
  See http://www.geocities.com/SiliconValley/Lakes/1434/pcm.html
Date: 28 Jul 1999 08:22:28
Message: <379EF77E.D073E664@puzzlecraft.com>
You can curve, twist and bend text any way you wish with Chris Colefax's
Object Bender.
I'd like to learn edge sculpting and face rounding myself. I think, but am
not sure, that POV treats the font like a spline sweep so it might be a bit
tricky rounding the face out.
steve
> Any thoughts?
> Thanks,
> Matt
Date: 28 Jul 1999 09:39:50
Message: <379f0826@news.povray.org>
Steve <ste### [at] puzzlecraftcom> wrote:
: You can curve, twist and bend text any way you wish with Chris Colefax's
: Object Bender.
  I think that bending ttf's is SLOW.
Date: 28 Jul 1999 09:51:50
Message: <379F09D4.F3896274@pacbell.net>
> : Object Bender.
I would agree with you on that.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 28 Jul 1999 15:44:25
Message: <379f5d99@news.povray.org>
Someone had done a bevelling include here someplace, most likely found
in one of the scene-file groups dating back to last summer or fall I
believe, not sure. It deformed the ttf text somehow. Looking at that
logo you gave the link to it didn't seem too difficult to do that at
least. You can easily difference shapes from the text to achieve some
new looks, I did the English alphabet letters individually once,
subtracting a inversed sphere from them. The existence of a complete
text changing include file of the sort you suggest is unknown to me.
Like you say, there are certainly programs which manipulate it though,
but it wouldn't be difficult to do the basics via macro or such I'm
sure.
Matt Swarm wrote:
> Hi Bob:
> starting points.
> Any thoughts?
> >> Any thoughts?
Date: 31 Jul 1999 11:04:47
Message: <37a2ec6d.82005290@news.povray.org>
On Tue, 27 Jul 1999 16:53:37 -0700, "Matt Swarm" <ide### [at] aolcom>
>Any thoughts?
IMO the easiest way to bevel the text is to export text to a modeller
and bevel it there (IIRC there way a simple modeller called "VSPOV" or
similar which could take in a 2D DXF object - as produced by Corel
Draw exporting text - raise it into 3D and bevel it).
However, what you're left with is meshes rather than true text...
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at http://www.who3d.cwc.net/
PS change ".duffcom" to ".net" if replying via e-mail
Date: 1 Aug 1999 13:06:31
Message: <37A4726F.A618D798@xs4all.nl>
Why wouldn't those things be possible? Have you tried it?
Remco
