POV-Ray : Newsgroups : povray.general : bump_trouble Server Time
10 Sep 2025 14:31:37 EDT (-0400)
  bump_trouble (Message 1 to 3 of 3)
Subject: bump_trouble
Date: 19 Jul 1999 04:54:26
Message: <3792E7EE.278889B3@xs4all.nl>
I'm having some trouble with bump_maps. It seems that when I apply a spherical
or cylindrical bump_map to an object and then rotate that object (around the
y-axis) the bump_map won't rotate with it. Could someone verify this? It doesn't
really matter what code I use, because I've tried it in several ways.
Remco
http://www.xs4all.nl/~remcodek/pov.html
Subject: Re: bump_trouble
Date: 19 Jul 1999 05:21:23
Message: <3792ED76.575207B3@pacbell.net>
> Regards,
> Remco
 Using Pov v3.1g and the following code I could not duplicate your problem.
Either one of the two commented out rotates rotated the bump map predictably
the same amount. Pov.gif was simply a gif image with a black background and
the word Pov printed in white. I did not try it with cylindrical mapping
but spherical worked just fine.
  sphere  { 0,1
 pigment  { rgb 1}
  normal  {
 bump_map { gif "pov.gif" interpolate 2 map_type 1 bump_size 1}
            // rotate 90*-y
            // rotate 90*-y
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 19 Jul 1999 06:06:02
Message: <3792F88F.D7290326@xs4all.nl>
> > Regards,
> > Remco
>   sphere  { 0,1
>  pigment  { rgb 1}
>   normal  {
>             // rotate 90*-y
>             // rotate 90*-y
> Ken Tyler
I see what I have been doing wrong now. The bump_map I was using didn't make
things very clear, with another gif I could figure it out. So, I should've tried
a little harder...
Thanks!
Remco
