POV-Ray : Newsgroups : povray.general : Mesh-object problem Server Time
30 Nov 2025 06:09:27 EST (-0500)
  Mesh-object problem (Message 1 to 6 of 6)
Subject: Mesh-object problem
Date: 17 Jul 1999 13:05:53
Message: <3790b7f1@news.povray.org>
I'm having problems with the mesh-object in Superpatch 3.1e.  Since I only
have Povray 3.1a, I can't say if it's also in POVRay 3.1e, f or g.
The problem is simply that I cannot make a mesh object.  Superpatch stops
with the message:
error: Attempt to malloc zero size block (File:
C:\incoming\povsrc\super31a\PARSE.C Line 3796).
(and the line causing the error is always the first thing in the mesh that
isn't a triangle, but a transformation, texture, or even a ' }' )
Is this a bug, or am I doing something wrong?
ZK
Subject: Re: Mesh-object problem
Date: 17 Jul 1999 16:47:39
Message: <3790EB91.75E7@geocities.com>
>  Since I only have Povray 3.1a, I can't say if it's also in
> stops with the message:
I think this is a known bug in SuperPatch to 3.1e which was briefly
discussed in povray.unofficial.patches a couple weeks ago. It is
not a problem in the official 3.1e.
It is sure to be fixed in the next SuperPatch version.
You could apply the fix discussed in that afore mentioned thread to
the SuperPatch sources and compile a new POV-Ray. (If you tell me you
actually want to do that, I can be more specific about it). another
possiblility is to get use MS-DOS version of the SuperPatch from
http://www.geocities.com/Athens/Academy/8764/spovraydjgpp.html
which is fixed (for that particular bug anyway)
http://www.interport.net/~dsharp
Date: 17 Jul 1999 16:51:00
Message: <3790EC5C.2A48@geocities.com>
I forgot to mention that, assuming it is that same mesh bug,
if you can use smooth_triangles instead of plain triangles
in your mesh, it will work. the malloc problem is only with
plain triangles.
Date: 18 Jul 1999 08:42:20
Message: <3791cbac@news.povray.org>
edna dornblazer heeft geschreven in bericht <379### [at] geocitiescom>...
>plain triangles.
Thanks for your help.  I think I'll just wait for the next Superpatch.  Or
maybe Povray 3.5...
ZK
Date: 18 Jul 1999 08:51:47
Message: <3792c959.211284099@news.povray.org>
On Sat, 17 Jul 1999 18:58:46 +0200, "Zeger Knaepen"
  Hi, Zeger. Why not grab the latest version, 3.1g for most platforms, if
the download time is not cost-prohibitive for you?
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 18 Jul 1999 08:54:40
Message: <3791ce90@news.povray.org>
Alan Kong heeft geschreven in bericht
<3792c959.211284099@news.povray.org>...
Because I want to use Superpatch-features.
ZK
