POV-Ray : Newsgroups : povray.general : Quality Settings Server Time
1 Dec 2025 11:07:46 EST (-0500)
  Quality Settings (Message 1 to 9 of 9)
Subject: Quality Settings
Date: 24 Jun 1999 00:37:18
Message: <3771b5fe@news.povray.org>
What calculations do the various Quality levels activate?  That section of
the Windows help file is messed up, so I can't tell if, for example,
'Compute texture patterns' goes with quality 5 or quality 6.
Mark
Subject: Re: Quality Settings
Date: 24 Jun 1999 08:46:17
Message: <37722899@news.povray.org>
For that matter, how do you change the settings?  I tried putting it in the
.ini file, but every render reported quality 9.
Date: 24 Jun 1999 09:43:26
Message: <377235fe@news.povray.org>
Edward C. <edw### [at] hotmailcom> wrote:
: For that matter, how do you change the settings?  I tried putting it in the
: .ini file, but every render reported quality 9.
  Try the command line parameter +q5 (you can set command line parameters
in the render/render options menu if I remember right).
Date: 24 Jun 1999 17:00:04
Message: <37729C4E.AF3AB4A9@aol.com>
Quality=n  (n is an integer 0 through 11 [POV-Ray 3.1]) added to any INI being used
should do okay.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 24 Jun 1999 17:02:32
Message: <37729CE2.DE6F7CC0@aol.com>
----quote----
Quality=n	Set quality value to n (0 <= n <= 11)
+Qn	Same as Quality=n
The Quality=n option or +Qn switch allows you to specify the image rendering quality.
You may choose to lower the quality for test rendering and raise it for final renders.
The quality adjustments are made by eliminating some of the calculations that are
normally performed. For example settings below 4 do not render shadows. Settings below
8
do not use reflection or refraction. The duplicate values allow for future expansion.
The values correspond to the following quality levels:
0, 1	Just show quick colors. Use full ambient lighting only. Quick colors are used
only
at 5 or below.
2, 3	Show specified diffuse and ambient light.
4	Render shadows, but no extended lights.
5	Render shadows, including extended lights.
6, 7	Compute texture patterns.
8	Compute reflected, refracted, and transmitted rays.
9	Compute media.
10	Compute radiosity but no media
11	Compute radiosity and media
The default is 9 if not specified.
----unquote----
This is how the POV-Ray 3.1 Scene help reads. The 0,1 and 2,3 and 6,7 are apparently
simply the same things.
> Mark
Date: 24 Jun 1999 19:37:25
Message: <3772C18B.876A2B92@earthlink.net>
hmm...
according to one of the blurbs that comes up in POV-Ray 3.1e, settings
10 and 11 are no longer valid..
Dan
Bob wrote:
> ----quote----
quality.
renders.
below 8
expansion.
used only
> at 5 or below.
> 9       Compute media.
> ----unquote----
> > Mark
>   http://members.aol.com/inversez/homepage.htm
Date: 24 Jun 1999 19:41:11
Message: <3772C266.F44C0048@pacbell.net>
Dan wrote:
> hmm...
> Dan
   Yes but Bob is and old timer around here so they are still valid
for him :)
Ken Tyler
mailto://tylereng@pacbell.net
Date: 24 Jun 1999 22:09:12
Message: <3772E51E.E3B41ABD@earthlink.net>
Ken wrote:
> Dan wrote:
> > hmm...
> > Dan
> for him :)
I always rather liked the "11" setting.  Reminds me of "Spinal Tap," and
the famous amplifiers that "go up to 11."
> Ken Tyler
Date: 24 Jun 1999 22:40:34
Message: <3772EC20.9714EE01@aol.com>
Old-timer eh? Well I'm hurt now (ha!).
I found no reference to the subtraction of +q10 and +q11.
Dan wrote:
> Ken wrote:
> > Dan wrote:
> > > hmm...
> > > Dan
> > for him :)
> > Ken Tyler
