POV-Ray : Newsgroups : povray.general : Macro with variable number of parameters... Server Time
1 Dec 2025 11:09:02 EST (-0500)
  Macro with variable number of parameters... (Message 1 to 10 of 19)
Subject: Macro with variable number of parameters...
Date: 18 Jun 1999 14:12:11
Message: <376a8bf8$1$pbaarep$mr2ice@news.povray.org>
Is it possible to create a macro with a variable number of
parameters?
I'm trying to create a macro that counts the number of
parameters passed to it and then issue the #macro definition.
Is this possible?
I want a way to make it so the user doesn't have to provide
information that isn't necessary.  Based on the value of the
first parameter, the second is always needed, but the third
may not be.  I'd like to allow the user to do the following.
myMacro(0,"a")
or
myMacro(1,"a","b")
The first and second parameter are needed, but if the first is a 0
(instead of a 1) the third value isn't necessary.
Anyone have any ideas?
  Suburbia is where the developer bulldozes out the trees,
  then names the streets after them.
  -- Bill Vaughn
   Friday, June 18, 1999 - 02:06 PM (EDT)
_-~-_-~-_-~-_-~-_-~-_-~-_-~-_-~-_-~-_-~~~~~~~~~~-_
+   Chris C. Conner                 +    This    +
+   cco### [at] amerisurecom-NOSPAM    +    space   +
+   con### [at] geocitiescom-NOSPAM    +    for     +
+   con### [at] usanet-NOSPAM          +    rent    +
~-_-~-_-~-_-~-_-~-_-~-_-~-_-~-_-~-_-~-__________-~
Subject: Re: Macro with variable number of parameters...
Date: 18 Jun 1999 15:33:19
Message: <376a9eff@news.povray.org>
I'd say it's not possible. Aside from the fact that a called #macro always
expects the same number of params specified in the original, there is a
problem of ambiquity. Let's say, out of 5 parameters the 3rd isn't
necessary. How would you go about omitting it?
The best I've managed was to have long parameters (strings or vectors) take
the value 0 as an alternative meaning "do not use". This, of course, is not
always applicable for vectors. Another thing is to make it possible to use,
for example, "3" instead of "<3,3,3>" by manually promoting the float to a
vector (#local Vector=Float+<0,0,0>;)
But what you want, I think is impossible.
Margus
con### [at] geocitiescom wrote in message
<376a8bf8$1$pbaarep$mr2ice@news.povray.org>...
>parameters?
>Is this possible?
>myMacro(0,"a")
>or
>myMacro(1,"a","b")
>  -- Bill Vaughn
Date: 19 Jun 1999 00:45:10
Message: <376b20bc.13826741@news.povray.org>
>parameters?
>Is this possible?
Is it possible to pass an array? If yes then that's one possible way
round it.
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at
http://www.geocities.com/Area51/Dimension/7855/
PS change ".duffnet" to ".net" if replying via e-mail
Date: 19 Jun 1999 11:15:34
Message: <376bb416@news.povray.org>
In povray.general con### [at] geocitiescom wrote:
: myMacro(0,"a")
: or
: myMacro(1,"a","b")
#macro myMacro(itemsAmount, stringArray)
Date: 19 Jun 1999 12:53:39
Message: <376dcac4.120103227@news.povray.org>
>: myMacro(0,"a")
>: or
>#end
Or just pass the array and use dimension_size.
Date: 21 Jun 1999 11:21:08
Message: <376e5864@news.povray.org>
Ron Parker <par### [at] fwicom> schrieb in im Newsbeitrag:
376dcac4.120103227@news.povray.org...
> >: myMacro(0,"a")
> >: or
> >#end
elements used in it (which makes the same as just typing an unused
parameter.
My idea is to use a macro with two Parameters. the first is a usual float.
the second could be a float or a vector; like this
#macro(bool,data)
    #if bool
        #declare u.data = a;
        #declare v.data =b;
    #else
        #declare data = a;
this of course assumes that the user enters the maco correctly (using only
two parameters if bool = 1 )
hope Icould help you
maesju **
Date: 21 Jun 1999 21:36:14
Message: <376ee88e@news.povray.org>
This probably isn't ideal but how about...
#macro myMacro2( val1, val2 )
    myRealMacro( val1, val2, "" )
#macro myMacro3( val1, val2, val3 )
    myRealMacro( val1, val2, val3 )
#macro myRealMacro( val1, val2, val3 )
...and use they both as...
--Rainer
<con### [at] geocitiescom> wrote in message
news:376a8bf8$1$pbaarep$mr2ice@news.povray.org...
> parameters?
> Is this possible?
> myMacro(0,"a")
> or
> myMacro(1,"a","b")
>   -- Bill Vaughn
Date: 4 Jul 1999 17:17:03
Message: <377FCF6D.E5B49458@giwersworld.org>
> parameters?
> Is this possible?
> myMacro(0,"a")
> or
> myMacro(1,"a","b")
	IF it is possible, it remains poor programming practice. Either
the first parameter is the number of additional parameters to be
passed or write two macros. Your examples would then pass (1,"a")
and (2,"a","b") Alternatively the passing routine can pass an end
of list marker.
	It is also a dangerous language that would permit what you want.
FORTH comes to mind.
<blink>-------please--don't-----------------</blink>
http://www.giwersworld.org/artii/
http://www.giwersworld.org/artiii/
Finally up on 99/06/22 updated 06/30
Download 'us-ascii' (1 KB)
Date: 4 Jul 1999 17:58:41
Message: <3780d89d.19745903@news.povray.org>
On Sun, 04 Jul 1999 17:17:33 -0400, Matt Giwer
C and C++ come to mind too.  I couldn't live without varargs.
Date: 4 Jul 1999 19:08:44
Message: <377FE9AB.68BBED2D@geocities.com>
No no no no no no.......... Argh................
So, does your code have lots of GOTO's also? Functions named things like
"function1()" and "func2()"? Void pointers cast all over the place?   ;-)
I never got into FORTH much, but I agree that C and C++ are very dangerous.
That's why I'm glad basic programming courses are switching over to Java.
