POV-Ray : Newsgroups : povray.general : Transparent Server Time
22 Jul 2026 17:08:48 EDT (-0400)
  Transparent (Message 1 to 7 of 7)
Subject: Transparent
Date: 1 Jun 1999 17:18:18
Message: <37544197.56DAD75B@tiac.net>
Is there a way to make my background transparent?
Say for instance I want to render an object and then use the
image as a layer in Photoshop on  top of an actual photo.
Like me standing next to an X-wing or something. I could
of course cut out the X-wing but if POV can already do
transparency I could just layer it.
Subject: Re: Transparent
Date: 1 Jun 1999 17:37:25
Message: <37544485.0@news.povray.org>
I use blue screen.
Make a plane behind it all one color with an ambient of 1, watch out for
reflections, don't use AA, then use your paint tool to make that color
transparent.
Phil Clute <pcl### [at] tiacnet> wrote in message
news:37544197.56DAD75B@tiac.net...
> ...coffee?...yes please! extra sugar,extra cream...Thank you.
Date: 1 Jun 1999 17:39:01
Message: <375444e5.0@news.povray.org>
Use an image format that supports an alpha channel (PNG
does) and put the +UA switch on the command line or in
your ini file.
Date: 1 Jun 1999 18:12:12
Message: <37554c2c.10927139@news.povray.org>
>your ini file.
...and don't use a sky sphere nor afloor plane.
Peter Popov
ICQ: 15002700
Date: 1 Jun 1999 22:03:20
Message: <37548184.87C4677C@xs4all.nl>
> >your ini file.
... but use background{}.
Date: 2 Jun 1999 12:36:51
Message: <37554f93.0@news.povray.org>
>> >your ini file.
Actually, you *can* use a sky_sphere, which is nice if you want a
metallic object to reflect the sky.  Here's what I did when I wanted
this effect:
#declare P_Cloudy = pigment {  bozo               // (based on P_Cloud3)
  colour_map {
    [0.0   rgb <0.850, 0.850, 0.850> ]
    [0.1   rgb <0.550, 0.600, 0.650> ]
    [0.5   rgb <0.184, 0.184, 0.309> ]
    [1.001 rgb <0.100, 0.100, 0.200>]
  turbulence 0.65  octaves 6  omega 0.707  lambda 2  scale <6,4,6>
#declare S_HalfSky = sky_sphere {
  pigment { gradient y
    pigment_map {
      [0.500 rgbt <0.5,0.5,0.5,1>]
      [0.500 rgb <0.184, 0.184, 0.309> ]
      [0.575 P_Cloudy scale <0.05, 0.40, 0.05> rotate z*30 ]
      [0.725 P_Cloudy scale <0.25, 0.15, 0.50> ]
    translate y*-0.5
    scale 2
This puts clouds in the top half of the sky sphere, but a 50% grey with
full transparency in the bottom half.  (I've found that 50% grey works
better than pure black or white when compositing the sprite over a
variety of differently-coloured background images.)
The only caveat I've discovered about creating sprites by this method is
that the alpha channel is derived from the first surface POV-Ray
encounters -- if you have a glass sphere with an opaque object inside
it, the alpha channel will *not* reflect the presence of the opaque
object; the background will show through the opaque object.
month ago, in the povray.bugreports group:
> Here's my solution: I create another scene with the same camera and
> objects. You remove the light_source.  And: the background is black,
> the opaque objects are white, and transparent objects vary from
> rgbt<1,1,1,0> (transmit=0 in the original scene) to rgbt<1,1,1,1>
> (transmit=1 in the original scene).  Of course, don't forget to set
> finish { ambient 1 diffuse 0 }.
> POV-Ray will directly render a 256-gray picture: the alpha channel
> you need.
> It works, but it needs more work than automatic alpha-channel
> rendering.
Jeff Lee         shi### [at] gatenet         http://www.gate.net/~shipbrk/
Date: 2 Jun 1999 15:42:27
Message: <37557CA2.CF8B4E57@tiac.net>
Thanks for the help all, much appreciated.
Phil
