POV-Ray : Newsgroups : povray.general : Insert file Server Time
1 Dec 2025 14:04:50 EST (-0500)
  Insert file (Message 1 to 10 of 11)
Subject: Insert file
Date: 2 May 1999 16:50:05
Message: <372cac6d.0@news.povray.org>
This might be the right place to post this question.
I have been just real reluctant to even mess with POVRAY since it wiped out
my last insert file and then went to the new text file format. When it came
out there was talk about a utility to convert the old file into the new
format, has anyone done this?
Subject: Re: Insert file
Date: 2 May 1999 17:13:51
Message: <372CB0B6.E4A16B79@bahnhof.se>
I'm not sure I understand what you mean..
there is a bug in POV 3.1e for windows that is in the SaveAs. It overwrites the
old and the new file at the same time.
insert file, meaning ?
//Spider    --  [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
And the meek'll inherit what they damn well please
	Get ahead, go figure, go ahead and pull the trigger
		Everything under the gun
			--"Sisters Of Mercy" -- "Under The Gun"
Date: 2 May 1999 18:10:27
Message: <372cbf43.0@news.povray.org>
Eh, no.
    What happened was due to my stupidity and the way POVRAY installs. I
installed 3.1 and saw that it didn't use the old insert file. So I deleted
it and reinstalled my old version. Not making backups. It over wrote my
insert file that I had worked on for years. So I reinstalled 3.1 so I could
use macro and have been trying to rebuild an insert menu.
    Now I have found a copy of my insert file which I carefully saved on a
different machine then promptly forgot. I want to convert it into separate
text files in proper directories to use in 3.1
    Hope that makes more sense....
Spider <spi### [at] bahnhofse> wrote in message
news:372CB0B6.E4A16B79@bahnhof.se...
overwrites the
out
came
> file://Spider    --
Date: 2 May 1999 18:55:34
Message: <372cc9d6.0@news.povray.org>
Bill DeWitt wrote in message <372cbf43.0@news.povray.org>...
[snip]
A bit, but I am still unclear on one fact: What _is_ an insert file?
Johannes.
Date: 2 May 1999 19:34:27
Message: <372cd2f3.0@news.povray.org>
POV3TMPL.TXT
The file which makes the insert function work.
Johannes Hubert <jhu### [at] algonetse> wrote in message
news:372cc9d6.0@news.povray.org...
> [snip]
> Johannes.
Date: 2 May 1999 19:41:31
Message: <372CD347.2FE5773C@bahnhof.se>
Ok. now i know what you mean, but I can't solve it. I've never had any use for
it. never heard of any such either.
Bill DeWitt wrote:
> Eh, no.
> overwrites the
> out
> came
> > file://Spider    --
Date: 2 May 1999 20:34:42
Message: <372ce112.0@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote in message
news:372CD923.390A05CB@aol.com...
> Look in the povray.binaries.utilities group.
> Or I could email it over.
    Looked and didn't find, does this news server delete older posts?
    I would appreciate it if you did e-mail it. TIA
Date: 2 May 1999 21:07:09
Message: <372CE8AC.5846F46B@aol.com>
Will do. But no, the news group posts are all there. It would be your news
reader at fault. The utility in question would date to around last autumn
and no doubt the reader is set to extinguish the posts from view back that
far. Probably a simple thing to reset, though not a good idea to keep so
many in off-line mode and all that.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 2 May 1999 21:08:48
Message: <372CE90E.C4AED531@aol.com>
Btw, you cross-posted, I failed (sorry Ken :) to notice that. Please
refrain from doing so. The news administrator suggests not to.
Date: 2 May 1999 21:49:11
Message: <372cf287.0@news.povray.org>
news:372CE8AC.5846F46B@aol.com...
> reader at fault.
    I had it set to search back 3 years, but I used the terms 'pov3tmpl.txt'
and/or 'insert'. I probably would find it under another term.
    Eagerly awaiting your e-mail.
