POV-Ray : Newsgroups : povray.general : Pentium Linus/Win timings Server Time
11 Aug 2024 21:25:49 EDT (-0400)
  Pentium Linus/Win timings (Message 1 to 10 of 10)
Subject: Pentium Linus/Win timings
Date: 27 Apr 1999 10:34:30
Message: <3725BD03.2781@icrf.icnet.uk>
I need to compare render times across different processors.
Unfortunatily I do not have access to any Intel processors.
I would be grateful if anybody could find times to process
the following:
        Site:     ftp.icnet.uk
        Login:    ftp
        password: email address
        directory: /pub/bmm/tmp
        files:  test.ray and test.ray.par
                (file size is 327k and the include file 51k)
        command: povray +Itest.ray +W1200 +H1200
and let me know the render time (Parse + Trace + Total)
and system being used.
Thanks
p.s. Trace time on a Silicon Graphics MIPS R10000, 195MHz
was 22 seconds.
____________________________________________
Suhail A Islam
Biomolecular Modelling Laboratory
Imperial Cancer Research Fund, P.O. Box 123
44 Lincoln's Inn Fields, London WC2A 3PX
Tel: (0171) 269 3380
Fax: (0171) 269 3258
email: isl### [at] icrficnetuk
http://www.icnet.uk/bmm/
Subject: Re: Pentium Linus/Win timings
Date: 27 Apr 1999 10:59:59
Message: <3725C1FF.B9342E46@pacbell.net>
> the following:
>         Site:     ftp.icnet.uk
>         Login:    ftp
> Thanks
> was 22 seconds.
> Suhail A Islam
Pentium 200 mmx win 98 Pov 3.1d
parse   3.0 sec.
trace  50.0 sec.
totatl 53.0 sec.
Memory consumed - 1,428,750
Ken Tyler
mailto://tylereng@pacbell.net
Date: 27 Apr 1999 13:37:19
Message: <3725E802.B77E21C@a.com>
islam wrote:
>         Site:     ftp.icnet.uk
>         Login:    ftp
Smallest Alloc:                 28 bytes   Largest:            24044
Peak memory used:          1383164 bytes
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Trace:    0 hours  0 minutes  15.0 seconds (15 seconds)
    Total Time:    0 hours  0 minutes  16.0 seconds (16 seconds)
Pentium II 350 MHz running under OS/2 Warp 4
Povray version 3.1a for OS/2 Warp
  See ya
    Udo
Email:        sicota.country(at)bigfoot(point)com
WWW-Pages:
Programming pages:
http://www.bielefeld.netsurf.de:8080/~u_mueller/program.html
Travel pages:
http://www.crosswinds.net/bielefeld/~sicota/index.html
Date: 27 Apr 1999 14:55:37
Message: <3725FA60.F13678AD@a.com>
U. Mueller wrote:
> islam wrote:
> >         Site:     ftp.icnet.uk
> >         Login:    ftp
I have noticed that you should post some other parameters like
antialising(on/off), jitter(on/off),...as the results vary depending on
the settings.
Just to add another result:
Smallest Alloc:                 12 bytes   Largest:            24028
Peak memory used:          1107472 bytes
Time For Trace:    0 hours  0 minutes  13.0 seconds (13 seconds)
    Total Time:    0 hours  0 minutes  14.0 seconds (14 seconds)
Pentium II 350 MHz running under Suse Linux 6.1 (Kernel 2.2.5)
Povray version 3.1
  See ya
   Udo
WWW-Pages:
Programming pages:
Travel pages:
Date: 27 Apr 1999 17:25:28
Message: <37261d38.0@news.povray.org>
test.ray 1200X1200, no AA:
parse: 0 sec
trace: 20 sec
total: 20 sec
peak memory used: 1429140 bytes
POVWin 3.1d on Win98 (highest render priority)
Pentium II Celeron 416MHz (FSB 83MHz * 5)
Margus
islam wrote in message <372### [at] icrficnetuk>...
>the following:
>        Site:     ftp.icnet.uk
>        Login:    ftp
>Thanks
>was 22 seconds.
>Suhail A Islam
Date: 27 Apr 1999 17:25:36
Message: <37261d40.0@news.povray.org>
>Povray version 3.1
Are you sure you used the right settings (1200X1200)? I don't think Linux is
THAT fast...
Margus
Date: 28 Apr 1999 06:04:05
Message: <3726CF48.693B88E@numerik.uni-kiel.de>
Just some data from a
UltraSPARC-II, 296 MHz, 640MB RAM
Peak memory used:    1218068 bytes
Time For Trace: 0 hours  1 minutes   3.0 seconds (63 seconds)
Total Time:    0 hours  1 minutes   4.0 seconds (64 seconds)
Of course I don't know why povray doesn't that beast working. Even on a 2
processor machine a idle of 80% is too much.
(Should I try the huge one? :-)
I will...
Axel
Date: 28 Apr 1999 15:03:41
Message: <37274DC7.E0F33671@a.com>
> >Povray version 3.1
> THAT fast...
Yep...it is...although if I set antialising and jitter to on...it takes
about 30 seconds...but he hasn't stated how to set them and these
settings are not needed here...
  See ya
   Udo
WWW-Pages:
Programming pages:
Travel pages:
Date: 28 Apr 1999 19:25:11
Message: <37278ac7.0@news.povray.org>
On a Pentium II 300MHz running POV 3.1e under Windows 98 with render
priority set to Highest:
Peak memory used:          1429163 bytes
Time For Parse:    0 hours  0 minutes   3.0 seconds (3 seconds)
Time For Trace:    0 hours  0 minutes  32.0 seconds (32 seconds)
    Total Time:    0 hours  0 minutes  35.0 seconds (35 seconds)
rygad
islam <isl### [at] icrficnetuk> wrote in message
news:372### [at] icrficnetuk...
> the following:
>         Site:     ftp.icnet.uk
>         Login:    ftp
> Thanks
> was 22 seconds.
> Suhail A Islam
Date: 2 May 1999 04:43:58
Message: <372C00BD.24EC528C@aol.com>
Using Normal priority and render window off:
Peak memory used:         1429078 bytes
Time For Trace:    0 hours  0 minutes  19.0 seconds (19 seconds)
Total Time:    0 hours  0 minutes  20.0 seconds (20 seconds)
Windows NT 4.0, PII 333mhz, VC++ compile of POV-Ray 3.1e
-Mike
