POV-Ray : Newsgroups : povray.general : Problems with ior Server Time
12 Aug 2024 03:25:50 EDT (-0400)
  Problems with ior (Message 1 to 7 of 7)
Subject: Problems with ior
Date: 10 Apr 1999 11:54:51
Message: <370f663b.0@news.povray.org>
Hi everybody
As some of you will know I have been attempting to model rough water.
I could not understand why I had no control of the textures until I tried
adding some transparent cones for the spray - they showed...I eventually
traced the problem to ior, turn the ior off in the water HF and the cones
became transparent.
The same applies to stacked hf, the ior in the water makes some of the
higher hfs (I think the parts above the water surface)visible.
Unfortunately turning off the ior changes the waves considerably
Is this a variant of the double illumination bug? is there a fix?
I can partially fix it by placing other completely transparent Hf in the
stack but this only partially solves the prob and I hav'nt been able to work
out the mechanics of it, let alone understand or control it.
any ideas?
Mick
Subject: Re: Problems with ior
Date: 10 Apr 1999 15:27:44
Message: <370F9759.F4225641@Kopp.com>
Watch out for total internal reflection.  If the angle of incidence is
too shallow (the threshold angle is dependent on IOR), it will be reflected
instead of refracted.
-Nathan
Mick Hazelgrove wrote:
> Hi everybody
> became transparent.
> any ideas?
> Mick
Date: 10 Apr 1999 19:15:31
Message: <370FCC77.404D15B3@bahnhof.se>
Hmm, could It have someeething to do with the fact that a HF isn't a
"solid" that way??
Try using a box/HF intersection and I think you should get a better
result.
> Hi everybody
> became transparent.
> any ideas?
> Mick
Date: 10 Apr 1999 20:33:04
Message: <370fdfb0.0@news.povray.org>
Spider <spi### [at] bahnhofse> wrote:
: Hmm, could It have someeething to do with the fact that a HF isn't a
: "solid" that way??
  HF is as solid as a plane.
Date: 10 Apr 1999 21:08:15
Message: <370FE6E0.36443977@bahnhof.se>
ok.
I havent experimented with the solidity of it..
Date: 11 Apr 1999 01:19:30
Message: <371021ac.139608013@news.povray.org>
Which is to say "not as solid as a sphere."  At least, not as far as
media is concerned.  But both should work okay with ior, as POV
doesn't need to know the exit point for simple refraction
calculations.  Is it possible that our protagonist is not specifying
the same IOR for the cones?
Date: 11 Apr 1999 21:06:05
Message: <371138ed.0@news.povray.org>
Mick Hazelgrove wrote in message <370f663b.0@news.povray.org>...
>Hi everybody
>became transparent.
I don't know if it is, but the double illumination bug effects only smooth
height fields (as opposed to non-smooth ones that is).  You could try
removing the smooth keyword (if present) and seeing if that effects
anything.  Otherwise, I doubt it's a double_illuminate problem...
Matt
