POV-Ray : Newsgroups : povray.general : GFI Server Time
24 Jun 2026 07:50:39 EDT (-0400)
  GFI (Message 1 to 10 of 10)
Subject: GFI
Date: 26 Mar 1999 09:41:59
Message: <36fb9db2.17594375@news.povray.org>
Go for it.
Subject: Re: GFI
Date: 26 Mar 1999 09:53:12
Message: <36FB9E5B.A0960721@pacbell.net>
povray.org admin team wrote:
> Go for it.
 Thank you I am right now.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: GFI
Date: 26 Mar 1999 09:59:44
Message: <36FBA0D3.A956F1C0@ica.uni-stuttgart.de>
> Go for it.
Hey !!!!
This one icludes LINUX!!!!!!!!!!
Thank you Pov Team! Thank you Pov Team! Thank you Pov Team! Thank you
Pov Team!
PovTeam! Thank you Pov Team! Thank you Pov Team!
That's like x-mas and easter happen at the same day!
Marc
Marc Schimmler
Subject: Re: GFI
Date: 26 Mar 1999 10:08:17
Message: <36fba2e1.0@news.povray.org>
Marc Schimmler <sch### [at] icauni-stuttgartde> wrote:
: This one icludes LINUX!!!!!!!!!!
  And apparently general UNIX too. Cool.
Subject: Compiling 3.1e for UNIX (Was: GFI)
Date: 26 Mar 1999 11:17:06
Message: <36fbb302.0@news.povray.org>
I just compiled the brand new povray 3.1e on this SparcStation 5 with
SunOS and it seems to work fine.
  However, I had some problems with the makefile:
  1. The line:
X11 = /usr/openwin
had extra whitespaces at the end causing problems with the compilation.
This was caused because the line:
XLIBINC = -I$(X11)/include
expanded to "-I/usr/openwin     /include" instead of "-I/usr/openwin/include".
  Removing the spaces fixed the problem.
  2. The CFLAGS variable has the flag '-c' as it should but the compilation
is made this way:
$(ODIR)/atmosph$(OBJ)  : $(atmosphDEP)
	$(CC) $(CFLAGS) $(SRCDIR)/atmosph.c -o $@
  The gcc compiler (egcs-2.91.60) does not allow specifying both '-c' and
'-o' flags. Removing all the "-o $@" at the end of those lines fixed the
problem.
  Besides that, it seems to work fine.
  Some system information about this computer:
% uname -a
SunOS vuoritiainen 5.5.1 Generic_103640-24 sun4m sparc SUNW,SPARCstation-5
% gcc -v
gcc version egcs-2.91.60 19981201 (egcs-1.1.1 release)
Subject: Re: GFI
Date: 26 Mar 1999 11:56:07
Message: <36FBBC3D.1006D610@kolumbus.fi>
"povray.org admin team" wrote:
> Go for it.
Cool, though I'm having problems getting the bugger downloaded, maybe
it's just temporary
Subject: Re: Compiling 3.1e for UNIX (Was: GFI)
Date: 26 Mar 1999 11:59:29
Message: <36fbbcf1.0@news.povray.org>
>% gcc -v
FYI egcs-1.1.2 is out now ;)
Matt
Date: 29 Mar 1999 11:05:19
Message: <qqmlngg1dtt.fsf@goldach.fmi.uni-konstanz.de>
Nieminen Mika <war### [at] cctutfi> writes:
>   1. The line:
> X11 = /usr/openwin
The same is true for me.
> is made this way:
> problem.
Are you sure that this was the problem? I use "-c" and "-o" together
without any problems. In particular, I didn't have to change the lines.
Perhaps you've had some LF/CR problems due to incorrect unpacking.
http://www.fmi.uni-konstanz.de/~willhalm
Date: 29 Mar 1999 12:58:39
Message: <36ffbf4f.0@news.povray.org>
Thomas Willhalm <Tho### [at] uni-konstanzde> wrote:
: Are you sure that this was the problem? I use "-c" and "-o" together
: without any problems. In particular, I didn't have to change the lines.
  Its very strange. I tried to compile again, and now it works.
  I don't know what I messed up the last time.
: Perhaps you've had some LF/CR problems due to incorrect unpacking.
  No, I'm sure this wasn't the problem.
Date: 31 Mar 1999 08:23:10
Message: <qqmd81p3iai.fsf@goldach.fmi.uni-konstanz.de>
I know this kind of problems. Strange things happen and one will never
know the reason. See it pragmatically: Who cares when it works now?
