POV-Ray : Newsgroups : povray.general : Interrupt radiosity trace. Server Time
28 Apr 2026 06:08:27 EDT (-0400)
  Interrupt radiosity trace. (Message 1 to 3 of 3)
Subject: Interrupt radiosity trace.
Date: 7 Mar 1999 10:09:37
Message: <36e296b1.0@news.povray.org>
Hi all,
I lifted the following from Alan Kong's post in
povray.announce.frequently-asked-questions.
3.1c               1/29/99 Chris Young
Fixed radiosity preview with odd screen size.
Reinitialized max_trace_level & radiosity_trace_level properly
Fixed token at end of file with no cr/lf or newline
Does this mean that in 3.1e, it'll be possible to halt a radiosity trace without
having to
restart POV?
Andy
Subject: Re: Interrupt radiosity trace.
Date: 7 Mar 1999 12:05:49
Message: <36e2b1ed.0@news.povray.org>
In article <36e296b1.0@news.povray.org> , "Andrew Cocker"
without having to
> restart POV?
No, it is the other way around. On platforms that don't terminate between
each render you would get some unexpected results. This is fixed now and to
continue a render with radiosity will work a bit better now.
    Thorsten
You can observe at least the max_trace_level bug in the Windows and Mac
version of 3.1a: Create a scene and set do not set max_trace_level in that
scene In the statistics output you see something like "Max Level: 2/5" where
the 5 is the max_trace_level. Now change it to to some value other than the
default (which is 5), i.e. use 20. The you will see "Max Level: 2/20". Now
remove the max_trace_level again and you would expect "Max Level: 2/5" but
get  "Max Level: 2/20". In 3.1d this is fixed and you get as expected "Max
Level: 2/5". (I am not sure, but I think you can't see radiosity_trace_level
problem anywhere in the stats output.)
Date: 7 Mar 1999 16:38:58
Message: <36e2f1f2.0@news.povray.org>
Thorsten Froehlich wrote in message <36e2b1ed.0@news.povray.org>...
>without having to
>> restart POV?
>    Thorsten
Ah I see....okay, thanks
Andy
