POV-Ray : Newsgroups : povray.general : Spirals and. . .celestial bodies! Server Time
12 Aug 2024 17:20:37 EDT (-0400)
  Spirals and. . .celestial bodies! (Message 1 to 3 of 3)
Subject: Spirals and. . .celestial bodies!
Date: 4 Feb 1999 00:12:40
Message: <36b92c48.0@news.povray.org>
2 questions.
1) Anyone know of a web tutorial or information on modelling celestial
bodies? (moons, planets, etc.) and how to achieve a realistic eclipsed
effect?
2) How do I model say a spiral of beads or something?  I guess I would need
to use a polar equation with spheres spaced along the motion path of said
3-d polar equation?
Mike Metheny
lon### [at] vtedu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
Subject: Re: Spirals and. . .celestial bodies!
Date: 4 Feb 1999 02:59:06
Message: <36B95315.AADEE6D@pacbell.net>
Mike Metheny wrote:
> 2 questions.
> effect?
Someone around here has a physicaly correct motions for planets
include file. I seem to recall that it was posted in one of the
scene files or utilities groups but may be wrong about that.
> 3-d polar equation?
> Mike Metheny
> lon### [at] vtedu
For spiraling beeds you can set that up fairly easily with a loop.
Try changing values for #while and values for translate and rotate
to see the effects they have.
camera{location<0,0,-25>look_at 0}
light_source{<0,0,-400>,1}
// start loop at zero
#declare aa=0;
// set counter amount
 #while  (aa<36)
   // a union of objects to twist. As they are not as origin they
   // will orbit as they are rotated
   union{
    sphere{<-.5,0, .5>,0.5}
    sphere{< .5,0, .5>,0.5}
    sphere{<-.5,0,-.5>,0.5}
     pigment{rgb 1}
      finish{specular .5}
    //sets the rotation amount: count 36 x 10 = 360 or 1 full twyst
     rotate y*10*aa
// to center object on screen
    translate y*-10
// translate in the +y direction as object is rotating
  translate<0,.5*aa,0>
 //end union
//  adds + 1 for each tick of the while counter so it will
//  not loop endlessly - ie stops when count reaches 36
#declare aa=aa+1;
// end of loop
After you play with this for a while throw it away and go see the
tutorials at spake.org. There is a set of six tutorials that cover
#unions, #while, #if, #next, #case, etc. They are written to be
understood for the most part by beginners but it takes a while to
get past the sheer volume they throw at you all at once. I sent the
pages to my email and studied them of line with pov open :)
http://www.spake.org/rtimes/
Hope this helps.
Ken Tyler
tyl### [at] pacbellnet
Date: 4 Feb 1999 07:42:14
Message: <36b995a6.0@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
:> 2) How do I model say a spiral of beads or something?
: For spiraling beeds you can set that up fairly easily with a loop.
  If you just want a spiral galaxy you may also use just the spiral
pigment type (as used in Colefax's galaxy include file).
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
