I've been working a bit with a orthorgaphic camera, and wanted to do a little
tag for my images, so ok. I go ahead. but, this doesn't take much of place on
the image, but there still is a MAJOR time difference between renderspeed for
ALL the image. I wonder why this is?
ok, there is transparency involved, but I didn't expect so big differences.
here are some times with a bit more advanced image than the one I include. This
one is the same tag, but has a image map and a heightfield in it, that really
changes other rendertimes. but I think it is speaking enough.
time(s) Memory(b)
merge: 3724 30241894
union : 380 30241894
render settings :
antialias off
width = 800
height = 1221
please keep the ratio :-)
another setting for test-renders :
640x994
version :
Pov-ray 3.1d, official compile, ran under win95. 96Mb ram. p166mmx in 200mhz
#version 3.1;
global_settings {
assumed_gamma 1.0
light_source {
<3, 3, -30>*100
color rgb 1
#declare Image = "fyr1_1.png"
#declare Scale = 1800/1179; // (original Y)/(original X)
#declare S = 15;
#declare siz = 0.1;
merge {
box {
<0,0,0>,<2.4*siz,siz,siz>
interior { ior 2 }
pigment { colour rgb <1,.98,.98> transmit 1 }
translate -2*siz*z
union {
text {
ttf "c:\win95\fonts\merlinn.ttf",
"Spider", 1, 0
scale siz
scale (x+y)*0.75+z
rotate (y*-2)+(x*-2)+(z*-1)
text {
"Lighthouse", 1, 0
scale siz
scale (x+y)*0.45+0.80*z
rotate (y*-.5)+(x*-.5)+(z*-.1)
translate 0.62*y*siz
translate -0.75*siz*z
interior { ior 2.1}
pigment { colour rgb <1,1,0> transmit 0.8 }
scale <S*Scale,S,1>
translate <-0.5*S*Scale,-0.5*S,0>
normal {
bumps 10
frequency 0.50
turbulence <1.30, 1.30, 1.25>
octaves 30
omega 1/30
scale 1/10
translate z
normal {
gradient z
sine_wave
normal_map {
// [0/4 ripples .008 frequency 15 turbulence <1.2, 1.3, 1.25> octaves 30
omega 1/30]
[1/4 ripples .008 frequency 15 turbulence <1.30, 1.30, 1.25> octaves 30
omega 1/30]
[2/4 waves .001 frequency 15 turbulence <1.20, 1.30, 1.35> octaves 30
omega 1/30]
[3/4 waves .001 frequency 15 turbulence <1.25, 1.25, 1.20> octaves 30
omega 1/30]
[4/4 ripples .008 frequency 15 turbulence <1.30, 1.20, 1.25> octaves 30
omega 1/30]
scale 1/20
orthographic
location <0.0, 0, -S>
direction 0.9*z
right Scale*S*x
up S*y
look_at <0.0, 0.0, 0.0>
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
<snip!>
Did you try to manually bound it? Sometimes helps a *lot* .
Peter Popov
ICQ: 15002700
I didn't try in this case, I will.
> <snip!>
> Peter Popov
> ICQ: 15002700
//Spider
