What waveform is used in a bozo as default ?? I can't seem to find it, perhaps
i'm blind...
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
> i'm blind...
> //Spider
From the official Pov-Ray documentions under section Patterns the
following was returned:
The following sections describe each pattern. See the sections "Pigment", "Normal",
"Patterned
Textures" and "Density" for more details on how to use patterns. Unless mentioned
otherwise, all
patterns use the
-> ramp_wave wave type by default <-
but may use any wave type and may be used with color_map, pigment_map,
normal_map, slope_map, texture_map, density, and density_map.
Ken Tyler
mailto://tylereng@pacbell.net
By default it uses ramp_wave. By using any other wave type you get
leopard-like spots.
Margus
Spider wrote in message <36D9ACB7.261DC9FC@bahnhof.se>...
perhaps
>i'm blind...
Thanx, i thought I had read it all, appearantly not then :-)
Ken wrote:
> > i'm blind...
> > //Spider
"Patterned
otherwise, all
> patterns use the
> Ken Tyler
//Spider
ok.
Thankyou
> leopard-like spots.
> Margus
> perhaps
> >i'm blind...
//Spider
