POV-Ray : Newsgroups : povray.general : Image maps and textures Server Time
12 Aug 2024 17:17:54 EDT (-0400)
  Image maps and textures (Message 1 to 4 of 4)
Subject: Image maps and textures
Date: 10 Feb 1999 06:56:43
Message: <36c173fb.0@news.povray.org>
I was wondering if it was possible to overlay an image map on an object that
already has a texture.
can you make the image map transparent in parts and put it on top of a
texture so that the texture shows through?
any help greatly appreciated.
Chris.
Subject: Re: Image maps and textures
Date: 10 Feb 1999 07:08:19
Message: <36C17675.1EFE9EBF@pacbell.net>
> Chris.
Yes it is possible. Read up in the docs on filter/transimit for
image maps. Basicaly you need to make the image_map's background
a single filterable color. You also need to know what the pallet
index for that color is. You could also specifiy a filter all
value if you prefer.
If I recall correctly the syntax for filtering a single color in a
image map is:
pigment{
 image_map{
   interpolate 2
  filter 255,1
The first number is the pallet index number for the backgound color
( I have choosen 255 = white for this example) and the second is the
filter amount. I may have that backward so check the docs. You can
files for this if possible because it uses a 256 color pallet for the
image which is compatible with the pov syntax for the feature.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Feb 1999 18:29:39
Message: <36C2163E.A83A6C44@aol.com>
To further enhance upon this hopefully, you can apply filtering or
tranmitting to larger amounts of the image_map by using a #while loop to
increase the number of palette index numbers used and can also vary the
filter value too. Many variations of this can be done. Hope this
somewhat thrifty example shows you the idea well enough. Beware, I had
to cancel this message once already because I left out the #end of the
loop.
#declare C=192; //starting palette index number
#declare FA=1; //starts with full filtering
texture {YourUnderlyingTexture}
 pigment{
  image_map{
   gif "MyImage.gif"
    interpolate 2
 #while (C>127) //ending palette index number
   filter PN,FA
 #declare PN=C; //palette index number
 #declare FA=FA-((192-C)/64); //filter value, based upon start/end
 #declare C=C-1; //countdown [integers only]
Please note that a custom palette or one ordered in some way makes for
better control than a mix and match kind, in which case a 24-bit targa
is a better candidate due to the palettelessness and should be more
color-based as seen in the picture.
> > Chris.
> image map is:
> pigment{
>  image_map{
>    interpolate 2
>   filter 255,1
> Ken Tyler
 mailto:inv### [at] aolcom?PoV
Date: 10 Feb 1999 23:52:15
Message: <01be557a$91bb60e0$0c0b010a@angela>
Something else to keep in mind is that POV will use the mask layer in TGA
files with this format. This gives you complete control over the overlay.
Gordon
Bob Hughes <inv### [at] aolcom> wrote in article
<36C2163E.A83A6C44@aol.com>...
> loop.
> texture {
>  pigment{
>   image_map{
>    gif "MyImage.gif"
>     interpolate 2
>    filter PN,FA
>  #end
> Ken wrote:
object that
a
> > > Chris.
> > image map is:
> > pigment{
> >  image_map{
> >    interpolate 2
> >   filter 255,1
> > Ken Tyler
>   http://members.aol.com/inversez/POVring.htm
