![](/i/fill.gif) |
Start by doing a general while loop for it, something like :
#declare Numx = 10;
#declare Numy = 10;
#declare Numz = 10;
#declare Ny =0;
#while(Ny<Numy)
#declare Nx =0;
#while(Nx<Numx)
#declare Nz=0;
#while(Nz<Numz)
sphere { <0,0,0>,1 pigment { White } translate
<-0.5*Nx,Ny,-0.5*Nz> }
#declare Nz=Nz+1;
#declare Nx=Nx+1;
#declare Ny=Ny+1;
#declare Numz=Numz-1;
#declare Numx=Numx-1;
and then when the loop works something resembling what you want, you
change the indata variables for the start parameters of a #macro, like
#macro place(Numx,Numy,Numz)
<insert code>
Then ytou change it until it fits. in this case I'd make Num as a
vector, and use Num.x, num.y, Num.z in the macro...
Hope it helps.
note : This code is untested and is probably not what you were after.
//Spider
![](/i/fill.gif) |
