POV-Ray : Newsgroups : povray.general : Mapping images on to prisms Server Time
28 Apr 2026 10:27:19 EDT (-0400)
  Mapping images on to prisms (Message 1 to 6 of 6)
Subject: Mapping images on to prisms
Date: 28 Jan 1999 15:33:33
Message: <36B0C996.175C3DC2@nacstock.ac.uk>
Hi
I'm trying to map an image on to the 'end' of a prism but no matter what
I do it always maps onto the 'side' of it. Basically I'm trying to
create a 7 sided coin with an image mapped on the 'heads' and 'tails'
side. This is what I've tried:
prism {
  linear_sweep
  linear_spline
  -0.9, 0.9,  7,
< 0.623, 0>, < 0, 0.782>, < 0.223, 1.757>, < 1.123,  2.19>, < 2.023,
1.757>, <2.246, 0.782>, <1.623, 0>
pigment{
      image_map {
                 gif "50p_tails.gif"
                 once
               scale <2.46, 2, 0>
Any ideas?
Mike Varley
mik### [at] nacstockacuk
Subject: Re: Mapping images on to prisms
Date: 28 Jan 1999 16:14:09
Message: <36B0D3F6.4330D7B@spiritone.com>
Yes, this will happen. Image maps will move forever through the z axis, the
once option only applies to the x-y plane. In order to place an image map on
the other side, you need to make two objects with the same height and width
but with half the depth, then on the second one place the second image but
be sure to rotate it correctly or it will appear backwards.
Josh English
eng### [at] spiritonecom
Mike Varley wrote:
> Hi
> prism {
>   linear_sweep
>   linear_spline
>   -0.9, 0.9,  7,
> pigment{
>       image_map {
>                  gif "50p_tails.gif"
>                  once
>                scale <2.46, 2, 0>
> Any ideas?
> Mike Varley
Date: 28 Jan 1999 16:31:15
Message: <36b0d723.0@news.povray.org>
On Thu, 28 Jan 1999 13:17:42 -0800, Josh English <eng### [at] spiritonecom> wrote:
You might also try some trickery with the radial pattern:
  #macro DoubleImage( front, back )
    radial
    pigment_map {
      [.5 front]
      [.5 back rotate 180*y]
  #declare f=pigment{image_map{ sys "heads.bmp" once } translate -.5}
  #declare b=pigment{image_map{ sys "tails.bmp" once } translate -.5}
  #declare coin=cylinder {
    -.1*z,.1*z,1
    texture{pigment {color rgb 1}}
    texture {pigment {DoubleImage(f,b)}}
If you look at the front (-z) side of this simple round coin, you'll see
the heads image.  Look at the back (z) side and you see the tails image.
Date: 28 Jan 1999 17:07:31
Message: <36B0DFA3.C7D@merlin.net.au>
> Hi
Image maps project the image onto the x,y plane while prisms are created
in the x,z plane,
just rotate your prism around the x axis
> prism {
>   linear_sweep
>   linear_spline
>   -0.9, 0.9,  7,
   rotate x*-90 // ***** rotation added ********
> pigment{
>       image_map {
>                  gif "50p_tails.gif"
>                  once
>                scale <2.46, 2, 0>
> Any ideas?
> Mike Varley
Cheers, PoD.
Date: 29 Jan 1999 12:00:38
Message: <36B1EA22.31BA3605@spiritone.com>
Ok, so I was still thinking brute force... that is a great solution, kudos for
clever thinking.
I am working on a web site that collects this kind of specific questions, would you
mind if I used this solution for it (giving you full credit, of course)
Josh English
>     radial
>     pigment_map {
>       [.5 front]
>   #end
>     -.1*z,.1*z,1
Date: 29 Jan 1999 12:12:03
Message: <36b1ebe3.0@news.povray.org>
On Fri, 29 Jan 1999 09:04:35 -0800, Josh English <eng### [at] spiritonecom> wrote:
>clever thinking.
You may, but you'll also want to give credit to Chris Colefax for his
contribution.  His version was posted both here (in povray.newusers)
and in CGRR, I think, and is basically the same idea but maps a
different texture on each face of a cube. (And is thus vastly more
complex.)
