POV-Ray : Newsgroups : povray.general : HF question Server Time
23 Jul 2026 12:48:30 EDT (-0400)
  HF question (Message 1 to 10 of 17)
Subject: HF question
Date: 24 Jan 1999 03:19:36
Message: <36AAD70E.114F71BA@pacbell.net>
Anybody have an idea how to map a height field to the inside
of a sphere ? Preferably 360 degrees in all directions.
Any chance Colefax's bend.inc could be used in this regard ?
Ken Tyler
tyl### [at] pacbellnet
Subject: Re: HF question
Date: 24 Jan 1999 06:12:18
Message: <36ab0012.0@news.povray.org>
I think one of the better known heightfield tools / toolsets could map a
heightfield to a sphere and export the result as a POV-mesh. Unfortunately I
don't remember which one (I don't even remember the names of all of them,
but hey, *you* are the linkmaster ;-) Maybe it was HF-Lab?
Johannes.
Ken wrote in message <36AAD70E.114F71BA@pacbell.net>...
>Ken Tyler
Date: 24 Jan 1999 06:14:52
Message: <36ab00ac.0@news.povray.org>
inside
You love Leveller, right? :) Wasn't there someone who wrote
a plugin for it to map heightfields to objects? I'm not
sure, but...
Julius
Date: 24 Jan 1999 07:21:40
Message: <36AB1041.B28A8988@flash.net>
I suspect you are thinking of John Beale's application which
does this.
There is also a macro which does the same thing which has been
publically released.
Dan
> Johannes.
http://www.flash.net/~djconnel/
Date: 24 Jan 1999 11:20:38
Message: <36AB485F.5C4B6483@virginia.edu>
Darnit.... yeah...I can do it with my program which I never finished...
It is still a kludge (you need to convert the tgas to oct format first)
but I should be able to patch it to map interiors instead of exteriors
in very little time.  I'll try and get you a exe within 24 hours.
Steve
> Ken Tyler
Date: 24 Jan 1999 12:52:07
Message: <36AB5D40.A3C3721D@pacbell.net>
> inside
> sure, but...
> Julius
Yes Leveller can do spherical and IIRCC cylindrical HF's
in mesh export now. The thing is it does this externaly
and not internaly. I want the mountains or whatever terrain
pointing inward (inverted).
Ken Tyler
Date: 24 Jan 1999 12:55:20
Message: <36AB5E01.5D246F0@pacbell.net>
> Steve
> > Ken Tyler
It there an easy way to convert tga's to .oct ? I'm unfamiliar with
this process.
Ken Tyler
Date: 24 Jan 1999 17:21:25
Message: <36AB9CF1.EB7456B2@virginia.edu>
HF-Lab will do it.  Just load the tga and save as an oct... they are
huge files but I haven't implemented reading tga's yet...
Steve
> > Steve
> > > Ken Tyler
> this process.
> Ken Tyler
Date: 24 Jan 1999 19:44:28
Message: <36ABBE79.91A3D69E@virginia.edu>
Um, if leveller will do it, why don't you invert the height field and
map it to the exterior?  It should end up the same in the end shouldn't
it?
Steve
Date: 24 Jan 1999 20:13:28
Message: <36ABC52F.E22750ED@pacbell.net>
> it?
> Steve
If you invert the HF image that Leveller uses for height elevation
points all that will happen is that it will be a mirror of itself.
The elevations will still be positive and the terrain will still
be extruded outward from the sphere. Nice try.
Ken Tyler
