POV-Ray : Newsgroups : povray.general : Bounding takes time... Server Time
10 Jul 2026 04:44:09 EDT (-0400)
  Bounding takes time... (Message 1 to 3 of 3)
Subject: Bounding takes time...
Date: 23 Jan 1999 13:25:59
Message: <36AA1331.F122EC85@bahnhof.se>
Hello... Just a little question here...
I'm trying to place a lot of spheres in a postition, the Y pos is linear, adn the X/Z
is
smothly changed..
But, this little pice of code gives me a pain...
The bounding time is horrible.... (I'm not patient there.)
I'm using winpov, 3.1a .
Any ideas ???
//Spider
#declare drop = sphere { <0,0,0> 0.1 }
union {
  #local Drops = 1000;
  #local DropsInv = 1/Drops;
  #local EndX = 15;
  #local EndY = 20;
  #local Yc = DropsInv*EndY;
  #local Xc = DropsInv*EndX;
  #local s1 = seed(666);
  #local s2 = seed(777);
  #local N = Drops;
  #while(N>0)
    #local TransY = N*Yc;
    object {
      drop
      translate <exp(N)*Xc, TransY, 0>
      rotate <0,rand(s2)*360,0>
    #declare N=N-1;
  pigment { rgb 1 }
  translate -EndY*0.5*y
Subject: Re: Bounding takes time...
Date: 23 Jan 1999 18:41:41
Message: <36AA5D8B.490F8B3F@compuserve.com>
Spider,
    It's to do with the 'exp(N)' in the translation:
>>translate <exp(N)*Xc, TransY, 0><<
I substitued a '1' and it bounds ->much<- quicker.
e to the power of 1000, then e to the power 999, e to 998 ... are v. large numbers.
Why
would you want to translate something in the direction of x with a huge (near
inifinate)
value when y is only translated to a maximum of 15?
Hope this helps.
    Graham.
X/Z is
> smothly changed..
> Any ideas ???
> //Spider
> union {
>   #local EndX = 15;
>   #local EndY = 20;
>   #local N = Drops;
>   #while(N>0)
>     object {
>       drop
>     #declare N=N-1;
>   #end
>   pigment { rgb 1 }
Date: 23 Jan 1999 19:01:23
Message: <36AA61CB.B4858BBE@bahnhof.se>
*smile*
Yeah, I know its a foolish thing to do, the effect I had intended was :
loop between 0 and 1, step 1/10000, then multiply and so on..
I choose a log function, got smoother...
But the reason for the question is why it takes so long to bound them??
Is it the union ??? I think there ios a setting to break unions, can't remember it....
Is it this ?
oh... I'm getting nasty tired of stack faults... *sigh* max_trace_level can't be high
enough...
(50000 transparent objects, filtering and reflecting, all in view... this gives a lot
of
relection.... I want a high trace level. Are the stack settings better in dos version
than
windows ??? )
//Spider
Graham Redway wrote:
> Spider,
Why
inifinate)
> Hope this helps.
>     Graham.
X/Z is
> > smothly changed..
> > Any ideas ???
> > //Spider
> > union {
> >   #local EndX = 15;
> >   #local EndY = 20;
> >   #local N = Drops;
> >   #while(N>0)
> >     object {
> >       drop
> >     #declare N=N-1;
> >   #end
> >   pigment { rgb 1 }
