POV-Ray : Newsgroups : povray.general : Atmospheric Media Server Time
2 Dec 2025 00:40:31 EST (-0500)
  Atmospheric Media (Message 1 to 5 of 5)
Subject: Atmospheric Media
Date: 3 Jan 1999 14:23:02
Message: <368fc396.0@news.povray.org>
Can anyone possibly offer any help here? I've been trying to setup some
atmosphere using media, hoping to have spotlighs running through it. I've
followed the examples files that came with the distribution, but I can't get
my light beams to show up in the media?
My media statement is:
media {
  intervals 40
  scattering { 1, rgb 0.02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
And my lights are just spotlights with media_attenuation on. I've placed
regular cones to verify that the beams should be within my field of view,
but even though the cones show up, the beams never do (and yes, I have
removed the cones <g>).
Any help would be appreciated,
Darcy
djo### [at] inamecomNOSPAM
http://www.geocities.com/SiliconValley/Sector/4317
Subject: Re: Atmospheric Media
Date: 3 Jan 1999 14:28:28
Message: <368FC46C.C4372D79@pacbell.net>
> media {
>   intervals 40
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
> Darcy
Are you using high intensity spot lights ? I noticed in the example
scenes they have the color values pumped up to a fairly high level.
Try something like color rgb<3,3,3> and see what happens.
Ken Tyler
tyl### [at] pacbellnet
Date: 3 Jan 1999 17:38:48
Message: <368ff178.0@news.povray.org>
Ken wrote in message <368FC46C.C4372D79@pacbell.net>...
get
Thanks, I tried intensifying my lights and that seems to have done the
trick.
Although in my case I decided to crank it all the way to 15 or so. :)
Thanks again,
Darcy
Date: 3 Jan 1999 19:14:28
Message: <369007DE.D125B415@flash.net>
> trick.
Did you try reducing "extinction" from the default of 1 ?
Dan
http://www.flash.net/~djconnel/
Date: 4 Jan 1999 23:39:02
Message: <3691975F.9ADB5981@aol.com>
As Dan said about extinction in scattering statement a lower value than
1 typically increases brightness of the media interacted by lights,
however as Ken suggested about using more intense lights (I do use 1.5
total light color though) that may not be the way to go, especially rgb
15! Reason being, the rest of a scene needs to be considered; most of
all, textures.
Try increasing the scattering rgb instead.
Here's a complete pov script showing a spotlight illuminating the "air".
Please keep in mind this is all I've been able to come up with to check
atmosphere making so beware.
//BEGIN (check for line-wrapping)
light_source {
  0*x
  color rgb 1 //normal enough intensity for testing
  spotlight
  translate <-2, 0, 0>
  point_at <0, 0, 0>
  radius 15
  tightness 1 //default is 10
  falloff 30
  fade_distance 2 fade_power 1 //reduce reach
  media_interaction on
   media_attenuation off //with this off render speeds up considerably
camera { //an offset point of view
  location  <-3, 0,-9>
  direction 3*z
  look_at   <0, 0, 0>
//the "air" media
media {
 intervals 15 //if more than 2 lights, increase this integer
 samples 10,20
  confidence 0.96 //these two values don't have to be extremely high and
low
  variance 1/123
//ratio lower than 1 increases graininess at light/dark boundaries of
spotlights
   ratio 1
 //emission rgb .1 //not needed
 //absorption rgb .1 //not needed
 scattering {1,rgb .5 //increase rgb value for brighter lit "air",
darker unlit
  extinction .005} //zero if using sky_sphere
 density {rgb .5} //increase rgb value for brighter lit "air", darker
unlit
} //the scattering and density are of prime importance, density lesser
of two
//control object (should show up even if air does not)
box {-.5,.5 pigment {rgb 1} finish {ambient .1} rotate <30,30,30>
translate 1*x hollow}
//non-interacting light
light_source {<-2.5,-5,-10> color rgb .5 media_interaction off
media_attenuation off}
//comment out to see with sky_sphere instead
sphere {0,15 pigment {rgb<.3,.6,.9>} hollow}
sky_sphere { // daytime
  pigment
    gradient y
    color_map { [0.0 color rgb<0.8,0.9,1.0>] [1.0 color
rgb<0.6,0.7,0.9>] }
//END
> media {
>   intervals 40
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
> Darcy
=Bob
Download 'us-ascii' (1 KB)
