POV-Ray : Newsgroups : povray.general : Genral Question Server Time
12 Aug 2024 23:19:23 EDT (-0400)
  Genral Question (Message 1 to 4 of 4)
Subject: Genral Question
Date: 29 Dec 1998 23:58:27
Message: <3689DEA0.4D87BB57@pilot.msu.edu>
I'm trying to put an image map on top of a closed cylinder.  Except
the cylinder dissappears where the image ends.  How do I just get my
image on the clyinder with color behind it?
Subject: Re: Genral Question
Date: 30 Dec 1998 00:18:06
Message: <3689B7FA.AD90E2FA@randolph.spa.edu>
The simplest method is probably to just put the image on a disc (or another
cylinder), being careful to keep the surfaces apart slightly.
-Mark R.
Date: 30 Dec 1998 00:37:19
Message: <3689BBA9.95E5F5BF@pacbell.net>
> -Mark R.
  Or use a thin cylinder with the same diameter as the original
in an intersection. The pigment on the intersecting cylinder will
append itself to the end of the original.
Ken Tyler
tyl### [at] pacbellnet
Date: 30 Dec 1998 20:03:36
Message: <368BC864.7C49@acm.org>
If I'm understanding this correctly, all you need to do is layer another
texture under the image_map, something like this:
cylinder {
	POINT1, POINT2, RADIUS
	texture {pigment {color Red}} // this shows around the outside of the
			image_map ...
Hope this helps,
Darius
