POV-Ray : Newsgroups : povray.general : Can anyone explain this Server Time
28 Apr 2026 18:32:49 EDT (-0400)
  Can anyone explain this (Message 1 to 3 of 3)
Subject: Can anyone explain this
Date: 23 Nov 1998 16:24:39
Message: <3659d297.0@news.povray.org>
Can anyone explain why there is a gap between the triangles?
Mick
camera{location  <0.0, 0.5, -20.0>
look_at   <0.0, 0.0,  0.0>
light_source{<-30, 30, -30>,color rgb<1,1,1>}
#declare Roof = union{
#declare Rad = 1.5;
#declare D = Rad*2
#declare Circ = pi*D;
#declare Base = Circ/8;
#declare Height = -1;
#declare Peak = <0,0,0>;
#declare Pt1 = <-Base/2,Height,Rad>;
#declare Pt2 = <Base/2,Height,Rad>;
#declare Count = 0;
#declare Angle = 0;
#while(Count<8)
        object{triangle{Pt1,Peak,Pt2
                rotate y*Angle
     #declare Count = Count +1;
     #declare Angle = Angle + 360/8;
object {Roof pigment{White}}
Subject: Re: Can anyone explain this
Date: 23 Nov 1998 19:07:07
Message: <3659F7A9.74DCB072@Kopp.com>
> Mick
Change the code to compute the base from
to
  #declare Base = 2*Rad*tan(pi/8);
I got this formula from
http://www.geom.umn.edu/docs/reference/CRC-formulas/book.html
(in section 5.3 "Regular Polygons")
-Nathan Kopp
Date: 23 Nov 1998 20:43:43
Message: <365A0F52.654D847F@flash.net>
There's really no need for formulas... let POV do the work:
#local dTheta = 45;
#local Pt1 = vrotate(<0, Height, Rad>, dTheta/2 * y);
#local Pt2 = <-1, 1, 1> * Pt1;
#local Roof =
  union {
    #local T = 0;
    #while (T < 360)
      triangle {
        Pt1,
        0,
        Pt2
        rotate T * y
      #declare T = T + dTheta;
http://www.flash.net/~djconnel/
