POV-Ray : Newsgroups : povray.general : Q: vector promotion Server Time
25 Jun 2026 02:42:04 EDT (-0400)
  Q: vector promotion (Message 1 to 4 of 4)
Subject: Q: vector promotion
Date: 12 Nov 1998 15:25:25
Message: <364B446C.923BA800@peak.edu.ee>
Hi all,
I've got this problem (not serious, but got me wondering)...
When a macro param is a vector (e.g. I use dot operators on it), it seems I
can't use a float identifier to represent it - it doesn't get promoted to a
vector. Example:
#macro MyMacro(Vector)
	(Vector.x + Vector.y + Vector.z)
MyMacro(<3,3,3>) is OK but
MyMacro(3) gets an error
Why is the float not promoted to a vector? Is it because POV can't tell the type
of a macro param?
Margus
Subject: Re: Q: vector promotion
Date: 12 Nov 1998 17:54:18
Message: <364B671C.F8C@merlin.net.au>
Margus Ramst wrote:
> Hi all,
> vector. Example:
> #end
> of a macro param?
> Margus
The input parameter becomes whatever type is passed to it, so if you
give it a float value, it is a float type variable.
You could try
#macro MyMacro(InputVector)
#local Vector=InputVector*<1,1,1>;
Cheers, PoD
Date: 12 Nov 1998 20:31:20
Message: <364d8bf7.163825061@news.povray.org>
On Thu, 12 Nov 1998 22:26:21 +0200, Margus Ramst <mar### [at] peakeduee>
>of a macro param?
Right.  You can force the promotion by multiplying it by <1,1,1> or
adding it to <0,0,0>
Date: 13 Nov 1998 03:47:56
Message: <364BF22F.8EA36D6A@peak.edu.ee>
Thanks, this is the solution.
A remark, though: you can't redefine a float identifier as a vector identifier,
so this has to be done by declaring a new variable.
Margus
