POV-Ray : Newsgroups : povray.general : Macros in 3.1 (not a bug report!) Server Time
11 Jul 2026 05:04:15 EDT (-0400)
  Macros in 3.1 (not a bug report!) (Message 1 to 3 of 3)
Subject: Macros in 3.1 (not a bug report!)
Date: 17 Jul 1998 17:23:58
Message: <35afb2de.0@news.povray.org>
How do you exit from a macro?  For instance, you have called a macro, and a
certain condition is reached, and you want the macro to exit.  How?
#macro DoMacro ( a, b, c )
    blah blah...
    #if ( something = true )
        #endmacro
    more junk...
Also, is there any way to goto somewhere?
    blah blah...
here:
    blah blah...
        #goto here
    more stuff...
Thanks for any help.  :)
Alan Grainger
E-mail - scy### [at] geocitiescom
Homepage - http://alansworld.home.ml.org
Subject: Re: Macros in 3.1 (not a bug report!)
Date: 18 Jul 1998 01:13:46
Message: <35B01F61.EE0DCB6@no13.net>
>     blah blah...
>         #endmacro
>     #end
>     more junk...
> #end
>     blah blah...
> here:
>     blah blah...
>         #goto here
>     #end
>     more stuff...
> #end
The easiest way I know of doing the first is placing the code inside a
#while loop with a simple switch. say
#macro DoMacro ( etc )
	#local Switch = 0;
	#while (Switch = 0)
			#local Switch = 1;
As for the second, again placing sitches for various sections means that
instead of a literal goto, segments of the macro will be skipped. And if
you want to go backwards, intead of forwards, maybe the goto location
should be another macro in its own right.
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
Date: 20 Jul 1998 12:40:40
Message: <35b364f8.0@news.povray.org>
Alan Grainger wrote in message <35afb2de.0@news.povray.org>...
You can do it all with "whiles" and "ifs" (actually with "whiles" alone, but
"ifs" are nicer sometimes):
Your version:
>    blah blah...
>        #endmacro
>    #end
>    more junk...
>#end
becomes:
#macro DoMacro( a, b, c )
   blah blah...
   #if (something = false)
      more junk...
and this one:
>    blah blah 1...
>here:
>    blah blah 2...
>        #goto here
>    #end
>    more stuff...
>#end
becomes:
   blah blah 1...
   #declare first_time = true
   #while (something = true | first_time)
       blah blah 2...
       first_time = false
   more stuff...
(I'm not sure that I got the syntax right, but you catch my meaning).
One of the first things you learn in advanced programming courses (and even
in good general/basic ones) is, that you don't need "Goto" at all.
Everything can be written in much better and readable style with "ifs" and
"whiles".
Simply ask yourselve whenever you crave for a "Goto": "How can I do it
without?". There always is an answer, and after some time you will find
yourself using "Goto" less and less, until it becomes natural not to use it.
Although it would be nice if POV-Ray had the other kind of while (which is
executed at least once), which would
create code without the "first_time" thing:
   blah blah 1...
   #do
       blah blah 2...
   #while (something = true)
   more stuff...
Hope it helps,
Johannes.
