POV-Ray : Newsgroups : povray.general : Transform into jpg Server Time
27 May 2026 16:40:56 EDT (-0400)
  Transform into jpg (Message 1 to 3 of 3)
Subject: Transform into jpg
Date: 12 Jul 1998 20:17:20
Message: <35A943D8.32175972@geocities.com>
Hello,
I'm a new user!  I just saved a file, but it is in .mdl.  How can I
change/save it as .jpg file?
Thanks!
Subject: Re: Transform into jpg
Date: 12 Jul 1998 20:55:03
Message: <35A93EB2.478EB8E7@pacbell.net>
It souds like you have created a file in moray.
If this is so you still need to process the file
through a raytracing program, the best in my
opion is povray. In moray there should be an
export function. If you have povray on your
system chose export to pov. You then need
to render the scene usng pov which will create
a *.tga file by default. Then to get a jpg image
file you will then need to take the tga file you
created into an image processing/converting
program like PhotoShop or PaintShopPro or
any other program that can convert targa
images into jpg.
I hope this helps. If you need more help feel
free to ask.
K.Tyler
bun### [at] geocitiescom wrote:
> Hello,
> Thanks!
Date: 13 Jul 1998 20:03:00
Message: <35AA91A1.86755AA5@hotmail.com>
Hi there,
You obviously used moray here. You should know that the actual rendering
of the picture is done by POV and not by moray, moray is just some sort
of GUI. The mdl file can only be used by moray and doesn't represent a
rendered image, but a scene composition.
The picture you're looking for is somewhere in you're POV directory or
wherever you've directed it to. it is called *.tga (the standard output
format of Povray). You can convert tga pictures with paint programs
(like Paint Shop Pro or Photopaint or something like that) or with image
convertors. Of course, jpeg is one of the (attractive) options for
internet use... or for using your drive space economically.
CU around,
JK
> Hello,
> Thanks!
