This looks like a "feature" of many programming languages that use
floating point numbers, including POVRay's. It's caused by inaccuracies
in the floating point calculations, such that tests like "T = 1.0" or "T
< 1.0" produce weird results. Try using a test such "abs(T - 1.0) <
0.01" where 0.01 is a sufficiently small number for the accuracy you
require, and things should work okay.
Andrew
Ob disclaimer: Of course, I might be wrong...
Guy Rauscher wrote:
> Hi!
> This bug exsited in the 3.0 version as well but I just found out about
> it now. In certain cases (maybe its related to the use of numbers with a
> decimal point) a while loop such as this: #while(I<1) loops one time too
> many (as if it was #while(I<=1)). Just run the attached script.
> Guy
[most of example snipped]
> // Doesn't work!
> #declare T = 0;
> #declare Tinterval = 0.1;
> #while(T < 1)
> #declare T = T + Tinterval;
> #debug concat("T",str(T,1,1)," ")
> #end
> Andrew
> Guy Rauscher wrote:
> > Hi!
> > Guy
> > // Doesn't work!
> > #declare T = 0;
> > #while(T < 1)
> > #end
Odd, POVRay is supposed to do that already.
According to the docs "A value of 0.0 is false and any non-zero value is
true. Note that extremely small values of about 1e-10 are considered
zero in case of round off errors."
