![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi all.
I'm looking for a way to distribute spheres randomly on the surface of a
triangle so that no sphere centre lies outside the confines of the
triangle. The triangle may be any 3 points. The next bit is that I would
like to do this using only POV 3.0 code. Any help is greatly
appreciated.
regards
Nathan O'Brien
no1### [at] no13 net
http://www.no13.net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmmm. This isn't a solution really, but maybe something to lead you to
one? Since any triangle may be divided into two right-triangles, maybe
you could do that. With a right triangle, its a simple matter of
trigonometry to figure how far a point is from the vertical "stem" given
the hieght along the stem, ie:
this point-> / | <- at this height
/_____|
Then you could position the sphere randomly between the "stem" and the
hypotenuse.
Hmm. A thought, anyway.
- Jamis Buck
buc### [at] cs byu edu
Nathan O'Brien wrote:
> Hi all.
> appreciated.
> regards
> Nathan O'Brien
> http://www.no13.net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <357BD7B4.6FDE6EC0@no13.net>,
Nathan O'Brien <no1### [at] no13 net> writes:
>Hi all.
>appreciated.
This snippet of code should do it. Because of a bug in POV, I can't use
the .v property of 2D - vectors so the code is a bit longer then
should be needed. Let me know how this works.
#declare P1x = 0 //First corner of the triangle
#declare P1y = 0
#declare P2x = 1 //Second corner of the triangle
#declare P2y = 0
#declare P3x = 0 //Third corner of the triangle
#declare P3y = 1
#declare E1x = P2x-P1x
#declare E1y = P2y-P1y
#declare E2x = P3x-P2x
#declare E2y = P3y-P2y
#declare E3x = P1x-P3x
#declare E3y = P1y-P3y
#declare n = 0
#while (n < 1) //change 1 to how many spheres you want...
#declare Pxx = 0.25 // add random function for spheres center, x
#declare Pxy = 0.25 // add random function for spheres center, y
#declare ydec1 = -1*E1y*(Pxx-P1x)+ E1x*(Pxy-P1y)
#declare ydec2 = -1*E2y*(Pxx-P2x)+ E2x*(Pxy-P2y)
#declare ydec3 = -1*E3y*(Pxx-P3x)+ E3x*(Pxy-P3y)
#if(((ydec1 >= 0) + (ydec2 >= 0) + (ydec3 >= 0)) = 3)
//sphere definition here
#debug "Within bounds\n"
#else
#debug "Not within bounds\n"
#declare n = n + 1
Best of luck :)
/Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here is a file that I wrote that does it a little bit differently. It
calculates the three vectors for the sides of the triangle. Then it
picks a point inside the triangle by multiplyng one edge vector by a
random number between 0 and 1, finding the vector to the opposite
corner, and then multiplying that by a random number between 0 and 1.
This always yields a point inside the triangle. Then it calculates the
perpendicular distances to the three edges and uses the smallest
distance for the radius.
camera{
location <4,4,-10>
look_at <0,0,0>
light_source{
<10,7,-20>
color rgb <1,1,1>
#declare P1 = <-3,-3,0> \\ put your three points here
#declare P2 = <0,4,0>
#declare P3 = <3,0,0>
#declare A=seed(3)
#declare vec1 = P2-P1
#declare vec2 = P3-P2
#declare vec3 = P1-P3
#declare counter = 0
#while (counter < 300)
#declare some_center = P1 + rand(A)*((vec2 * rand(A))+vec1)
#declare dist_vec1 = vlength(
vcross(vec1,(some_center-P2)))/vlength(vec1)
#declare dist_vec2 = vlength(
vcross(vec2,(some_center-P3)))/vlength(vec2)
#declare dist_vec3 = vlength(
vcross(vec3,(some_center-P1)))/vlength(vec3)
sphere{
some_center, min(dist_vec1, min(dist_vec2,dist_vec3) )
\\ draw a circle that touches the edge of the
triangle
pigment{ color rgb <0,1,1>}
#declare counter = counter + 1
triangle{
P1, P2, P3
pigment { color rgb <1,1,1> }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> appreciated.
You could try something like this:
#declare _RO_tempver = version #version 3.0
#ifndef (random_seed) #declare _RO_rand = seed(0) #else #declare _RO_rand =
seed(random_seed) #end
#ifndef (object_size_turb) #declare object_size_turb = .5 #end
#ifndef (object_count) #declare object_count = 10 #end
union {
#declare _RO_count = 0 #while (_RO_count < object_count)
#switch (rand(_RO_rand))
#range (0, .333)
#declare _RO_RP1 = P1 + (rand(_RO_rand) * (P2 - P1))
#declare _RO_RP2 = P1 + (rand(_RO_rand) * (P3 - P1)) #break
#range (.333, .667)
#declare _RO_RP1 = P2 + (rand(_RO_rand) * (P1 - P2))
#declare _RO_RP2 = P2 + (rand(_RO_rand) * (P3 - P2)) #break
#else
#declare _RO_RP1 = P3 + (rand(_RO_rand) * (P1 - P3))
#declare _RO_RP2 = P3 + (rand(_RO_rand) * (P2 - P3))
object {random_object
scale 1 + ((rand(_RO_rand) - .5) * object_size_turb * 2)
translate _RO_RP1 + (rand(_RO_rand) * (_RO_RP2 - _RO_RP1))}
#declare _RO_count = _RO_count + 1 #end }
#version _RO_tempver
For example (when saved as RandObj):
camera {location <1, 2, -5> look_at <0, 0, 0>}
light_source {<-40, 80, -100> rgb 1}
#declare P1 = <-2, -1, -1>
#declare P2 = <3, 0, 0>
#declare P3 = <1, 3, 1>
#declare random_object = sphere {<0, 0, 0>, .3}
#declare object_count = 100
#declare object_size_turb = .3
object {#include "RandObj" pigment {wrinkles
color_map {[0 rgb <1, 0, 0>] [1 rgb <1, 1, 0>]}}
finish {phong .5 phong_size 15}}
Of course, this is a very simple example. You could easily add support
to automatically orient the random_object to the normal of the triangle,
and to make the number of objects used for each triangle dependant on
the surface area of the triangle.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
