POV-Ray : Newsgroups : povray.general : Insignia in POV-ray Server Time
13 Jan 2026 20:21:55 EST (-0500)
  Insignia in POV-ray (Message 1 to 3 of 3)
Subject: Insignia in POV-ray
Date: 24 Apr 1998 13:03:05
Message: <3540C5C9.37D3@digiquill.com>
I'm working on a Saturn 5 model, and I'm trying to paint the insignia on
it. USA, Flags, etc.
I was wondring if there is a way to model these markings in CSG, instead
of using an image_map.
What I was thinking is a "texture intersection." Imagine a cylinder and
a box overlapping in space. Only show the cylinder, but color it white
on points outside the box, and red inside.
Can this be done? Is there another way?
Thanks in advance.
Chris Jeppesen
Go see my Orbital Mechanics Explained Page!
http://www.geocities.com/CapeCanaveral/Launchpad/3392/
EMail I will read: Chr### [at] digiquillcom
Subject: Re: Insignia in POV-ray
Date: 27 Apr 1998 13:52:46
Message: <6i2fnh$34j$1@oz.aussie.org>
That is possible to do, but it takes a bit of work.
For example, say I have a 10-unit-tall white cylinder, of radius 2, and
I want to put a 1-by-1 red square about 1/4 of the way from the top end
(but only on one "side" of the cylinder):
  // CylSquar.pov
  #declare C_Cyl_Square = colour rgb <1,0,0> // the red square
  #declare C_Cyl_Rest   = colour rgb <1,1,1> // the white surrounding it
  #declare P_Cyl_Y = pigment { gradient y
    colour_map {
      [0.70 C_Cyl_Rest]   // 0.00 through 0.70 (0.75 minus half the
      [0.70 C_Cyl_Square] //  square's height) is white
      [0.80 C_Cyl_Square] // 0.70 through 0.80 is red
      [0.80 C_Cyl_Rest]   // 0.80 through 1.00 is white again.
  #declare P_Cyl_X = pigment { gradient x
    pigment_map {
      [0.25 P_Cyl_Y]     // Taking advantage of the symmetry of the
      [0.25 C_Cyl_Rest]  //  X gradient here.
  #declare P_Cylinder = pigment { gradient z
    pigment_map {
      [0.50 P_Cyl_X]     // Now we ensure that the square appears on
      [0.50 C_Cyl_Rest]  //  only one side of the cylinder, rather than
    }                    //  going all the way through.
    translate <0,-0.5,-0.5>  // Centre the pigment on where the cylinder
    scale <2,10,4>           //  will be, and scale it appropriately.
  cylinder { <0,-5,0>, <0,5,0>, 2 pigment { P_Cylinder }}
  camera { location <0,0,-20> look_at <0,0,0> }
  light_source { <-100,100,-200> colour rgb <1,1,1> }
That's a lot of work for a simple square, but you could easily use that
sort of thing to produce the black-and-white markings on the Saturn V
(the radial pattern will be quite helpful for that, in places).
Things like the "USA" are certainly possible to do, though it will be an
extremely laborious process.  The stars on the flag will be a headache,
too, but the stripes and field are fairly easy:
  // FlagTest.pov
  #declare C_Flag_Red   = colour rgb <1,0,0>
  #declare C_Flag_White = colour rgb <1,1,1>
  #declare C_Flag_Blue  = colour rgb <0,0,0.75>
  #declare P_Flag_Stripes = pigment { gradient y
    colour_map {
      [ 0/13 C_Flag_Red]   [ 1/13 C_Flag_Red]
      [ 1/13 C_Flag_White] [ 2/13 C_Flag_White]
      [ 2/13 C_Flag_Red]   [ 3/13 C_Flag_Red]
      [ 3/13 C_Flag_White] [ 4/13 C_Flag_White]
      [ 4/13 C_Flag_Red]   [ 5/13 C_Flag_Red]
      [ 5/13 C_Flag_White] [ 6/13 C_Flag_White]
      [ 6/13 C_Flag_Red]   [ 7/13 C_Flag_Red]
      [ 7/13 C_Flag_White] [ 8/13 C_Flag_White]
      [ 8/13 C_Flag_Red]   [ 9/13 C_Flag_Red]
      [ 9/13 C_Flag_White] [10/13 C_Flag_White]
      [10/13 C_Flag_Red]   [11/13 C_Flag_Red]
      [11/13 C_Flag_White] [12/13 C_Flag_White]
      [12/13 C_Flag_Red]   [13/13 C_Flag_Red]
  #declare P_Flag_FieldX = pigment { gradient x
    pigment_map {
      [0.45 C_Flag_Blue]
      [0.45 P_Flag_Stripes]
  #declare P_Flag_FieldY = pigment { gradient y
    pigment_map {
      [6/13 P_Flag_Stripes]
      [6/13 P_Flag_FieldX]
  box {0,1 pigment { P_Flag_FieldY } translate -0.5 scale <1.75,1,0.01>}
  camera { location <0,0,-2> look_at <0,0,0> }
Hope this helps!
Jeff Lee         shi### [at] gatenet         http://www.gate.net/~shipbrk/
Date: 25 Apr 1998 06:09:59
Message: <m3g1j2p5zc.fsf@clodomir.rezel.enst.fr>
Chris Jeppesen <chr### [at] digiquillcom> writes:
Yeah. One can just have two parts of the cylinder. See? Give the intersection
of the cylinder and the box a red texture, and give a white one to the other
object, which would be the difference between the cylinder and the box.
Roland.
bob### [at] casimirrezelenstfr -- Linux, POV-Ray, LaTeX
