POV-Ray : Newsgroups : povray.general : This sounds stupid... Server Time
27 May 2026 22:04:41 EDT (-0400)
  This sounds stupid... (Message 1 to 3 of 3)
Subject: This sounds stupid...
Date: 31 Mar 1998 14:07:46
Message: <35213F02.62B4@frontiernet.net>
Okay, time to make a fool of myself in a public forum.
Is there any way to set the default directory that PovRay compiles the
images to without completely reinstalling the program? I am using 3.02
right now, and I'm sure there is a way but browsing the menu's and help
files didn't get me anywhere, so I stand on a soap box and scream :)
Any help would be greatly appreciated.
Saif.
Subject: Re: This sounds stupid...
Date: 31 Mar 1998 14:32:23
Message: <352144C7.8D859BBD@findus.aq.com>
Hey, that's not a stupid question.
It took me a while to figure it out myself when I needed to change it.
Open the povray.ini file, which is in the renderer directory I think,
but not sure whic directory. Anyway, open povray.ini in notepad (or
other text editor) and change the line (or add it if there is none)
+Oc:\povwin\images
(or Output File=)
Or whatever directory you choose. Or delete the line (or comment out)
for output to the input file's directory)
Hope it helps.
> Saif.
Date: 31 Mar 1998 16:11:21
Message: <35215b84.28562911@10.0.2.33>
On Tue, 31 Mar 1998 11:32:23 -0800, Colin Bennett <cdb### [at] findusaqcom>
>+Oc:\povwin\images
>(or Output File=)
To edit the INI file easily, choose "Edit master POVRAY.INI" from the
Tools menu.
The line in question in my povray.ini is
Output_File_Name=D:\mine\IMAGES\traced\
where d:\mine\images\traced is the directory I want the images to be
in.  It's the last line in my file; if yours came from a standard
installation, it's probably the last line in yours, too.
