POV-Ray : Newsgroups : povray.general : Re: Animation utilities Server Time
27 May 2026 22:05:20 EDT (-0400)
  Re: Animation utilities (Message 1 to 6 of 6)
Subject: Re: Animation utilities
Date: 25 Mar 1998 23:42:12
Message: <3519DCA4.8B9A44C8@doc.mssm.edu>
Videdit doesn't read TGA's or any other POVRAY file type...just stupid
DIB's.  And, it doesn't do MPEG, just AVI's.
Anyone know where the source to CMPEG is? A simple recompile in 32
bit mode should fix the memory limitation.
Fleb wrote:
> For Win3.11 up, you can use VidEdit, a very... well.. adequate program
> for doing frame-by-frame anims.
> It should still be at:
> ftp.microsoft.com/developr/drg/Multimedia/Jumpstart/VfW11e/ODK/WINVIDEO/
> (don't ask how I found this)
> And you'll want an FTP prog that can download multiple files, 'cause
> this is an install set, not a ZIP type file.
> Dylan Beattie wrote:
> > I've got a couple of POV-Ray generated animation sequences, and I'd like
> > to put them together into a short MPEG or AVI movie, and possibly add
> > music/sound effects as well. Is there a freeware/shareware/PD package
> > available which will create AVI/MPEG files from TGA's, and will allow
> > you to add an audio track? (Obviously they can be done using different
> > packages if necessary) Has anyone used any good packages for doing this
> > sort of thing? - I've got the CMPEG DOS encoder already, but it can only
> > handle fairly small image files.
> > Cheers
> > Dylan
Date: 10 Apr 1998 22:38:08
Message: <352ED790.E00598AD@concentus-tech.com>
I use Corel Draw and have created a macro that inserts the
files into an AVI.  The file can be saved as an mpeg but the
quality is low and it takes a long time.  Should be easy if
you can get a copy of Corel Draw.
> > > Cheers
> > > Dylan
Robert K. Casto
Software Engineer             E-Mail: cas### [at] concentus-techcom
Concentus Technologies           WWW: www.concentus-tech.com
525 Metro Place N. Suite 490   Phone: (614) 792-3197
Dublin OH 43017
Download 'us-ascii' (1 KB)
Date: 23 Apr 1998 21:57:15
Message: <01bd6f24$6f615f00$707a89d0@reboot>
Check out http://www.rio.com/~reboot/moviola.html
It's not completed yet, but here's your chance to contributed ideas and
suggestions for what I hope will be the "ultimate" Freeware animation
utility program.
--Gary.
program
Date: 27 May 1998 15:52:14
Message: <356C6EEE.23DC@msctech.com>
It's a late reply, but Correl has a product called Lumier that I use
that lets you do frame by frame AVI or MOV direct from TGA, with the
ability to add soundtracks and scene fades.  It ran me $50.00.
Christopher E. Naujok, P.E.,CEP
President
MSC Technologies, Inc.
cna### [at] msctechcom
www.msctech.com
> Cheers
> Dylan
Date: 10 Sep 1998 10:58:02
Message: <2c891MioQSFJ091yn@jagor.srce.hr>
In article <3519DCA4.8B9A44C8@doc.mssm.edu>,
Hm, try on ftp.carnet.hr/pub/utils/cmpeg
I think they had a source, not sure now...
        Mike
Date: 11 Sep 1998 13:36:17
Message: <35F9517E.1B33@merlin.net.au>
>         Mike
Try ftp://ftp.mpeg.org/pub/mpeg/mssg/
They have source for mpeg2enc which is what I assume cmpeg uses as its
encoder.
Best of luck, PoD.
