POV-Ray : Newsgroups : povray.general : [Q] When tranparent surfaces isn't that transparent Server Time
18 Apr 2026 22:14:22 EDT (-0400)
  [Q] When tranparent surfaces isn't that transparent (Message 1 to 8 of 8)
Subject: [Q] When tranparent surfaces isn't that transparent
Date: 25 Feb 1998 09:57:02
Message: <34f431eb.0@news.povray.org>
Hi Pov People!
I've run into this problem: When we're modelling a tranparent object and
place it on another surface (a floor, a table etc.) we get an ugly
effect. The bottom surface of the transparent object will have the same
y-value as the surface that the object is placed on. Is this something
POV don't like? As an example I've included a minimalistic POV file with
a "floor" and a simple transparent object. As you'll see the bottom
surface of the transparent object goes ape (since it lies in the same
plane as the "floor"?). Can someone explain to me why this happens?
Thanks!
-Rune
The .pov file:
global_settings
   assumed_gamma 2.2
   ambient_light 0.8
background { color rgb <0.9, 0.9, 0.9> }
camera
   location <100, 100, 100>
   angle 18
   look_at  <0,5,0>
light_source { <250, 200, -100> color 1.5 }
// Floor
#declare T1 = texture
  pigment { rgb <.5, .5, .9> }
  finish { ambient 0.70 diffuse 0.70 }
mesh
  smooth_triangle
    <-500, 0,  500>, <0,1,0>
    < 500, 0,  500>, <0,1,0>
    <   0, 0, -500>, <0,1,0>
  texture {T1}
// Transparent object
#declare T2 = texture
  pigment { rgbt <.6, .6, .6, 0.90> }
  finish { ambient 0.5 diffuse 1.0 }
mesh
  smooth_triangle
    <-10, 0,   5> <0, -1, 0>
    <  0, 0, -10> <0, -1, 0>
    < 10, 0,   5> <0, -1, 0>
  smooth_triangle
    <-10,  0,   5> <0, .6, .8>
    < 10,  0,   5> <0, .6, .8>
    <  0, 20,   0> <0, .6, .8>
  smooth_triangle
    < 10,  0,   5> <0.4,0.82,-0.4>
    <  0,  0, -10> <0.4,0.82,-0.4>
    <  0, 20,   0> <0.4,0.82,-0.4>
  smooth_triangle
    <  0,  0, -10> <-0.4,0.82,-0.4>
    <-10,  0,   5> <-0.4,0.82,-0.4>
    <  0, 20,   0> <-0.4,0.82,-0.4>
 texture {T2}
Remove "SPAM?NO!" to reply. My home is at: http://home.sol.no/~runew
Download 'us-ascii' (4 KB)
Subject: Re: [Q] When tranparent surfaces isn't that transparent
Date: 25 Feb 1998 12:05:15
Message: <qqm1zwrehtg.fsf@uni-konstanz.de>
Rune Winsevik <runew@SPAM?NO!compusoft.no> writes:
> POV don't like?
This is exactly the point.
Povray has problems to detect which surface is the upper one. So due to
rounding error it choses the bottom of the transparent object for one ray
and the floor for another one.
Solution:
Put the transparent object slightly above the floor.
I hope this helps.
ThW
P.S.: Please don't post HTML-code to newsgroups.
Tho### [at] uni-konstanzde
http://www.informatik.uni-konstanz.de/~willhalm/
Tschieses lavs ju
Date: 25 Feb 1998 12:22:25
Message: <34F45350.E163B036@penttech.com>
Thomas Willhalm wrote:
> Solution:
Or to avoid the effect of the tiny space between (possible
refraction/reflection) make the objet above the floor a little bit thicker so
that it reaches "into" the floor.
Johannes.
Date: 10 Sep 1998 03:23:46
Message: <35F6D15B.AC5F7A89@home.com>
Rune Winsevik wrote:
> Hi Pov People!
> and place it on another surface (a floor, a table etc.) we get an ugly
> same y-value as the surface that the object is placed on. Is this
> something POV don't like? As an example I've included a minimalistic
> POV file with a "floor" and a simple transparent object. As you'll see
> the bottom surface of the transparent object goes ape (since it lies
> in the same plane as the "floor"?). Can someone explain to me why this
> happens?
> Thanks!
> -Rune
> The .pov file:
> global_settings
>    assumed_gamma 2.2
>    ambient_light 0.8
> camera
>    angle 18
>    look_at  <0,5,0>
> // Floor
> mesh
>   smooth_triangle
>   texture {T1}
> mesh
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>  texture {T2}
The problem your encountering is called coincidental surfaces you can
read about in the povray docs.
Date: 10 Sep 1998 03:24:03
Message: <35F6D16C.ED752F3E@home.com>
> Hi Pov People!
> happens?
> Thanks!
> -Rune
> The .pov file:
> global_settings
>    assumed_gamma 2.2
>    ambient_light 0.8
> camera
>    angle 18
>    look_at  <0,5,0>
> // Floor
> mesh
>   smooth_triangle
>   texture {T1}
> mesh
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>  texture {T2}
Date: 10 Sep 1998 03:24:29
Message: <35F6D185.5AB3C24C@home.com>
> Hi Pov People!
> happens?
> Thanks!
> -Rune
> The .pov file:
> global_settings
>    assumed_gamma 2.2
>    ambient_light 0.8
> camera
>    angle 18
>    look_at  <0,5,0>
> // Floor
> mesh
>   smooth_triangle
>   texture {T1}
> mesh
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>  texture {T2}
Date: 10 Sep 1998 03:24:45
Message: <35F6D196.2C707DDF@home.com>
> Hi Pov People!
> happens?
> Thanks!
> -Rune
> The .pov file:
> global_settings
>    assumed_gamma 2.2
>    ambient_light 0.8
> camera
>    angle 18
>    look_at  <0,5,0>
> // Floor
> mesh
>   smooth_triangle
>   texture {T1}
> mesh
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>  texture {T2}
Date: 10 Sep 1998 03:25:11
Message: <35F6D1B0.BA3B457E@home.com>
> Hi Pov People!
> happens?
> Thanks!
> -Rune
> The .pov file:
> global_settings
>    assumed_gamma 2.2
>    ambient_light 0.8
> camera
>    angle 18
>    look_at  <0,5,0>
> // Floor
> mesh
>   smooth_triangle
>   texture {T1}
> mesh
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>   smooth_triangle
>  texture {T2}
