POV-Ray : Newsgroups : povray.general : A better scene Server Time
13 Jan 2026 22:05:32 EST (-0500)
  A better scene (Message 1 to 5 of 5)
Subject: A better scene
Date: 19 Feb 1998 08:48:17
Message: <34f13417.0@news.povray.org>
It is possible create same object with slightly deferent code. as u can see
from bellow
case 1:
    plane
    {    y, -5
         pigment { checker White, Black }
         scale <5,1,5>
         rotate 45*y
case 2:
    plane
    {    y, -5
         pigment { checker White, Black scale 5 rotate 45*y }
Both code will produce same result. In that case which is better?
Or which renders faster, if faster at all?
Dinesh Shah :-)
din### [at] indiamailcom
Subject: Re: A better scene
Date: 23 Feb 1998 16:07:48
Message: <34f1e5a0.0@news.povray.org>
Generally speaking there shouldn't be too much of a speed difference in
rendering although technically I think:
plane
    {    y, -5
is faster because it's only rotating the texture and not the object.
Lance Birch
Remove the smiley to e-mail.
http://www1.tpgi.com.au/users/ambient/lance
Date: 24 Feb 1998 03:24:34
Message: <34f3e485.0@news.povray.org>
Hi Birch
Thanks for the answer
I will look at the difference in more complex scenes
thanks
Dinesh Shah :-)
Lance Birch <:-)Lan### [at] tpgicomau> wrote in message
<34f1e5a0.0@news.povray.org>...
>plane
>    {    y, -5
>Lance Birch
Date: 1 May 1999 06:27:38
Message: <372AC8F0.1C97E900@gmx.net>
Dinesh Shah schrieb:
> case 1:
>     plane
>     {    y, -5
>          scale <5,1,5>
>          rotate 45*y
You scale the object and rotate it WITH the pigment on it
> case 2:
>     plane
>     {    y, -5
You scale the pigment and rotate it WIHTOUT the plane itself, so this should be
faster but:
It only works as a plane is infinite, try this with a box and you'll get
different results.
Date: 21 May 1999 05:06:21
Message: <3745158D.21399B40@verio.com>
Dinesh Shah wrote:
> Hi,
> case 2:
>     plane
>     {    y, -5
Case 2 will parse faster.  But not to a significant ammount that you
will notice anything.
(BTW, case 1 says scale <5,1,5> and scale 5 is the same as <5,5,5>)
oo o  o   (   (  ( (=-- inf### [at] veriocom --=) )  )   )   o  o oo
