POV-Ray : Newsgroups : povray.general : Discs Server Time
18 Apr 2026 22:14:28 EDT (-0400)
  Discs (Message 1 to 5 of 5)
Subject: Discs
Date: 8 Feb 1998 20:59:55
Message: <34df6152.602115766@news.povray.org>
G'day all.
I'm having a problem using the disc object. It doesn't want to be
seen. Here's the code I'm using and every time I run POVRAY nothing
shows up. In addition to this, can I use the "union" or "merge"
modifiers on discs ?
Global_settings { ambient_light color White }
light_source { <12, 12.5335, 12> color rgb <1,1,1> }
#declare Test_A = disc{<0,0,0>,.999,5 color Green rotate<-45,45,-45>}
   perspective
   location <0, 40.335,0>
   look_at <0,0,0>
   angle30
 Test_A
Subject: Re: Discs
Date: 9 Feb 1970 01:47:08
Message: <01bd351e$835ad120$be163acb@b>
Try adding the normal <0,1,0>.  Hope this helps.  (more info can be found
in the POV docs)
Lance Birch
Remove the smiley to e-mail.
http://www1.tpgi.com.au/users/ambient/lance
Subject: Re: Discs
Date: 9 Feb 1998 21:23:26
Message: <34e3ba0d.690367295@news.povray.org>
On Mon, 09 Feb 1998 01:59:55 GMT, bou### [at] rogerswaveca (Anthony
Bouttell) wrote:
>G'day all.
The big whoops I discovered, after actually reading the contents of
the message Window, has to do with the use of, "color", I should of
said :
#declare Test_A = disk{<0,0,0>,.999,5 texture{pigment{color Green}}
rotate<-45,-45,-45>}
( actually the <0,0,0> could have been coded 0 }
>camera {
>   perspective
>   look_at <0,0,0>
>   angle30
> Test_A
Subject: Re: Discs
Date: 12 Feb 1970 08:36:34
Message: <01bd37b2$8ef3f160$181657a8@W_tristan.gb.tandem.com>
I hope that realising an error didn't stop you from reading the replies
(Lance's in particular) because a disc needs a normal which points in some
direction.
Tristan Wibberley
(Remove the '.NO_LUNCHEON_MEAT' from my
email address to reply.)
Anthony Bouttell <bou### [at] rogerswaveca> wrote in article
<34e3ba0d.690367295@news.povray.org>...
| Bouttell) wrote:
| >G'day all.
| >camera {
| >   perspective
| >   look_at <0,0,0>
| >   angle30
| > Test_A
Subject: Re: Discs
Date: 10 Feb 1998 03:41:56
Message: <34e02005.0@news.povray.org>
[snip]
Just add the pigment keyword, like this:
#declare Test_A = disc {<0,0,0>,.999,5 pigment{color Green}
rotate<-45,45,-45>}
HTH,
        - Marco
