POV-Ray : Newsgroups : povray.general : Light amplification and artifact. Server Time
12 Oct 2025 03:40:16 EDT (-0400)
  Light amplification and artifact. (Message 1 to 3 of 3)
Subject: Light amplification and artifact.
Date: 28 Dec 2009 07:28:15
Message: <20091228092814.7e3a9811.john@johncoppens.com>
Hello guys and gals,
I was playing around with a simple scene for a Holiday card, and have two
problems. This years' focus was on trying glasses and contents as
believable as possible.
The scene is a PNG background image of some fireworks, and two glasses in
the front. The PNG is defined with an ambient light of 1, there is no
other light source in the scene.
Strangely, the image of the PNG coming through the glass seems to be
amplifying: Without the glasses, the image shows fine, through the
glass, the image saturates completely!
And the second problem is an artifact appearing in the middle line (row)
of pixels. This artifact seems to depend on the size of the image. In the
image I uploaded, it's not very visible (right side of each glass). In a
1200x900 version, it runs over the entire width (I'll render another one
of these later).
The output images are:
http://jcoppens.com/misc/with_glasses.png
http://jcoppens.com/misc/no_glasses.png
I'm running POV-ray 3.7beta34, on Linux.
John
PS: I still have to set ambient of the liquid to 0...
Subject: Re: Light amplification and artifact.
Date: 28 Dec 2009 12:59:15
Message: <4b38f1f3$1@news.povray.org>
> of these later).
> John
Do your glass pigment have both filter and transmit?
Do they add up to more than 1?
Normaly, the sum of transmit and filter must total at most 1, usualy to
a value slightly less than that, like filter + transmit <= 0.999. If it
adds up to more than 1, it will have an amplification effect. As you
cross 4 surfaces as you trverse the glass, the amplification will appens
4 times. So, even a value just slightly over 1 can have a very
niticeable effect.
Is the colour part larger than 1?
If it's larger than 1, it will also have an amplification effect.
Try a pigment of rgbt 1 or rgbf 1 for your glass and see what it does.
You can also try rgbft<1,1,1,0.5,0.5>
The ambient part for a transparent object is usualy barely dicernible,
if at all.
Date: 28 Dec 2009 21:01:56
Message: <20091228230155.8235a138.john@johncoppens.com>
On Mon, 28 Dec 2009 12:59:15 -0500
No, transmit is 0, filter is 1
> appens 4 times. So, even a value just slightly over 1 can have a very
> niticeable effect.
No. Color is 1
> if at all.
Yes, I set the ambient value to 0. The amplification was still there.
I just found a solution, but I don't really know why it is one. I'll
investigate a bit more:
I have enabled Fresnel reflection now, and the amplification disappeared
completely! The image is now quite acceptable.
Thanks for the suggestions, Alain! And best wishes for the holidays.
John
