POV-Ray : Newsgroups : povray.general : facets Server Time
24 May 2026 07:20:02 EDT (-0400)
  facets (Message 1 to 4 of 4)
Subject: facets
Date: 10 Jul 2002 17:30:15
Message: <20020710232840541+0200@news.povray.org>
Hello,
I wanted to have a surface reflecting with a sort of crystalline
facetted look. Like the object was polygonal, but with the polygons
possibly irregular. How could I accomplish this? I played with various
settings in the normal patterns and while discovering some are very nice
I found none good. Am I missing some? it seems so trivial, at least a
regular faceting.
-ric-
Subject: Re: facets
Date: 10 Jul 2002 17:39:22
Message: <3d2ca98a@news.povray.org>
I assume you've looked up "facets" in the documentation? There's a pattern
called just that which should create the exact effect you're describing.
 - Slime
[ http://www.slimeland.com/ ]
Subject: Re: facets
Date: 10 Jul 2002 19:21:17
Message: <20020711011949756+0200@news.povray.org>
I couldn't find it.. i looked up "facet" in the whole povuser.txt and I
found only reference to phong and specular microfactes which is clearly
not the correct thing. wheres houdl it be? under nomals ?
I'm using 3.1, is this a feature of the 3.5perhaps?
thanks
-r-
> pattern called just that which should create the exact effect you're
> describing.
Subject: Re: facets
Date: 10 Jul 2002 19:52:26
Message: <3d2cc8ba@news.povray.org>
"WhiteGandalf" <zus### [at] liberoit> wrote in message
news:20020711011949756+0200@news.povray.org...
Yes, and is not in 3.1. Maybe you could use checker and turbulence. Then
again, maybe that wouldn't look real good.
