POV-Ray : Newsgroups : povray.general : Alpha and background Server Time
25 Feb 2025 06:51:34 EST (-0500)
  Alpha and background (Message 1 to 10 of 10)
Subject: Alpha and background
Date: 28 May 2008 17:00:35
Message: <1ihr34tffecjbhdp73d79mqqpgdvoril7k@4ax.com>
I'm doing some rendering using the +FN +AU for transparency.  I'm not
sure yet if this will even work the way I want it to but.... I prefer
that there be no back ground whatsoever, so hopefully only the
rendered image will appear in an application I'm working on.  What do
I need to set as the background color, if any?  I believe I'd managed
to generate an image with only the checkered field showing behind the
object in the render window before but I don't seem to recall how I
managed it.
Lilith
Subject: Re: Alpha and background
Date: 28 May 2008 17:21:29
Message: <o4jr34l36lt496skfl3kf721ijk8suolce@4ax.com>
On Wed, 28 May 2008 16:00:35 -0500, Lilith <lil### [at] dcccdedu> wrote:
> What do
In the documents
3.3.2.2  Background
e.g for a black background
background { color rgb <0.000,0.000,0.000> }
Regards
Date: 28 May 2008 17:49:47
Message: <8qkr34df9t3489m1b1gqbd5mdonn65i63p@4ax.com>
On Wed, 28 May 2008 22:20:58 +0100, Stephen <mcavoysAT@aolDOTcom>
>> What do
>In the documents
>3.3.2.2  Background
I'm not sure you understand.  I need the background to ultimately be
transparent in the rendered PNG file.
Lilith
Date: 28 May 2008 17:54:14
Message: <483dd486$1@news.povray.org>
"Lilith" <lil### [at] dcccdedu> wrote in message
news:8qkr34df9t3489m1b1gqbd5mdonn65i63p@4ax.com...
>>> What do
>>In the documents
>>3.3.2.2  Background
with +ua it will be, no matter what your background-color is
cu!
Date: 28 May 2008 18:39:56
Message: <483ddf3c$1@news.povray.org>
Stephen's suggestion won't work if you are using the beta version of
POV-Ray. You will have to explicitly add transparency to the background,
like so:
background{ rgb 0 transmit 1}
Sam
Date: 28 May 2008 19:40:51
Message: <483ded83@news.povray.org>
> like so:
  Did you actually test that it works like that?
Date: 28 May 2008 19:41:41
Message: <483dedb5@news.povray.org>
  Just use those parameters (well, +ua, not +au). The background will
be transparent.
Date: 28 May 2008 20:33:57
Message: <483df9f5$1@news.povray.org>
>> like so:
Yes, I did. Why? +ua was also added to the command line.
These also work:
background{ 0 transmit 1}
background{ <0,0,0,0,1>}
Sam
Date: 29 May 2008 04:47:12
Message: <483e6d90@news.povray.org>
> >> like so:
  Ah, I missed that change in the changelog. Sorry.
Date: 29 May 2008 16:37:41
Message: <av4u34h9i8b3bn3tlqbinoj01jpn4n4g5c@4ax.com>
>be transparent.
Achh!  There we go.  Brain f*rt I guess.
Many thanks.  You're now in my will.
Lilith
